• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Active Member
    Help with Mtext glitch
    77 Views, 3 Replies
    06-19-2012 03:27 PM
    My office has been running into an interesting glitch with MText.  We have a standard text setup when anyone starts a new drawing using our standard templates.  For some reason, the first time you use Mtext, the result is not our standard.  If you use Mtext again, it then will look like our standard.  The weird part is that the settings are identical when you look at the properties.  The only difference is that the first Mtext under "content" of the properties, look like this:
    {\W1; text}
    This is not the case when you use Mtext again.  It only shows "text".  It only happens the first time you use Mtext after opening a file.  I've attached a PDF of what it looks like.  A is the non-standard first time Mtext.  B is the standard, second time Mtext.
    Any ideas?  Is this something that can be fixed?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Help with Mtext glitch
    06-19-2012 08:08 PM in reply to: wellsws
    That glitch plagued 2008 and 2009: ensure your version is fully patched and updated.
    If you can post an actual DWG someone might have more tips.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    06-20-2012 07:50 AM in reply to: wellsws
    Here's the dwg file.
    Active Member
    06-20-2012 07:51 AM in reply to: wellsws
    I forgot to mention, we are up to date on updates.
