• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    Help! Missing Installation Media
    133 Views, 3 Replies
    08-07-2012 09:54 AM
    Hi everyone,
    I am trying to transfer a stand alone copy of AutoCAD 2009 onto a new computer. The company i work for has kept terrible records of our software and licensing information. I am told we havent owned an AutoCAD Installation disk since 2004 so I'm assuming the users since that time have downloaded the installation media off of the autodesk website since we do not have any installation media on our servers.
    Now the oldest version you can download from autodesk is AutoCAD 2010. I need 2009 to do the license transfer. Does anyone know a work around to this problem so that i can get the 2009 software onto the new computer. Is there perhaps any way to create an image of the installation media or anything like that?
    Thanks for your help,
    Blair
    Please use plain text.
    TravisNave
    Re: Help! Missing Installation Media
    08-07-2012 10:24 AM in reply to: blegge
    You might be able to buy a replacement media from your Reseller.  The downloads for 2009 have expired and are no longer available.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    TravisNave
    08-07-2012 11:51 AM in reply to: blegge
    Philip posted the links here:
    http://forums.autodesk.com/t5/Installation-Licensing/Install-question/m-p/3568776#M48045
    Get it while you can.
    Travis Nave
    New Member
    08-07-2012 12:34 PM in reply to: blegge
    Thanks! Works Great :smileyvery-happy:
