• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    Accepted Solution
    Have run into an aperture problem
    295 Views, 9 Replies
    02-13-2012 03:47 PM
    Between Friday, when I am pretty sure it was fine and sometime today, my aperture went from fairly good sized to a pin prock. I can barely see it, and am having problems selecting things as it stays tiny. Went to options right off the bat, change to largest setting, it is still a pin ****. Grip boxes are still the right size. Crosshairs didn't change, just aperture. Any suggestions?
    HD
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Have run into an aperture problem
    02-14-2012 05:29 AM in reply to: HullDrafter
    What is APBOX set to?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    02-14-2012 07:31 AM in reply to: pendean
    0 (zero)
    Valued Contributor
    02-14-2012 07:34 AM in reply to: HullDrafter
    I changed it to one, but nothing happened.
    *Expert Elite*
    Patchy
    02-14-2012 07:43 AM in reply to: HullDrafter
    PICKBOX  ?
    Valued Contributor
    02-14-2012 07:50 AM in reply to: Patchy
    I don't understand, in the options/drafting/aperture size, I took the slder and put it to the max size yesterday, and it is still there. When I type "Pickbox" as a variable, it is set for (1). Change this variable, to 15-20 and I have my pickbox back. Thank you for your assisstance. I can pick things again.
    HD
    *Expert Elite*
    Patchy
    02-14-2012 08:05 AM in reply to: HullDrafter
    Sometime autocad try to write to registry but it fail, that's why you see people have to workaround and put variable settings in the acaddoc.lsp and force autocad to use it.
    Valued Contributor
    02-14-2012 08:13 AM in reply to: Patchy
    I appreciated the help both of you provided, I will have to add another command to my Acaddoc.lsp. Thank you for bringing this variable to my attention, I never knew it was there.
    HD
    Distinguished Contributor
    Kazo
    05-16-2012 06:34 PM in reply to: HullDrafter
    its ok to say pin **** you know???
    it actually relates to the size of the mark left if 'pricked' by a pin...nothing else.........lol!!!
    Kazo
    05-16-2012 06:36 PM in reply to: HullDrafter
    OMG..Autodesk blocked it...!!!!!!!!!
