• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Distinguished Contributor
    Hatch Area
    289 Views, 10 Replies
    01-05-2007 07:20 AM
    Hi all
    Why is it that when you list some hatch it lists the area and others don't???
    Kind Regards
    J
    Please use plain text.
    *Allen Jessup
    Re: Hatch Area
    01-05-2007 08:45 AM in reply to: jshiel
    I haven't seen this. But I don't often look at the area of a hatch. By
    chance is this happening in an old drawing? Possibly the area-less ones are
    the old style "block" hatches.
    Allen
    wrote in message news:5442295@discussion.autodesk.com...
    Hi all
    don't???
    Kind Regards
    J
    Re: Hatch Area
    01-05-2007 08:47 AM in reply to: jshiel
    Hi
    It is a new drawing, with new hatch, if you list the hatch the area is listed but for some reason some blocks of hatch doesn't list the area! Not to worry will keep looking into it.
    J
    *August
    Re: Hatch Area
    01-05-2007 08:51 AM in reply to: jshiel
    Do the ones that don't list have islands?
    JAT
    Aug
    wrote in message news:5442427@discussion.autodesk.com...
    Hi
    J
    *Rick Moore
    Re: Hatch Area
    01-05-2007 09:01 AM in reply to: jshiel
    I've seen it happen - attached is a file with two hatches, the one on the
    right does not display the hatch area, I've never known why.
    Rick Moore, AIA
    www.bgkarchitects.com
    *Allen Jessup
    Re: Hatch Area
    01-05-2007 10:50 AM in reply to: jshiel
    Very strange. I can't find any difference. However. If I recreate the
    boundary and rehatch the area. It will have a boundary.
    Allen
    "Rick Moore" wrote in message
    news:5442475@discussion.autodesk.com...
    Rick Moore, AIA
    Re: Hatch Area
    01-05-2007 09:52 PM in reply to: jshiel
    The hatch on the right is not associative. That could explain the lack of information for the area.
    Michael Grutter
    Cedar Engineering and Design Service
    http://www.cedarengineering.com
    *Jerry Runnels
    Re: Hatch Area
    01-06-2007 10:38 AM in reply to: jshiel
    It shows as associative in Properties on my system.
    wrote in message news:5443135@discussion.autodesk.com...
    Michael Grutter
    Active Contributor
    Re: Hatch Area
    08-10-2007 10:05 AM in reply to: jshiel
    yes i am having this same problem with getting area from hatches and even getting cumulative area from hatches and polylines.
    apparently other people at the office can do this, but I can't seem to.
    attached is 2 images - one is a brand new drawing where I drew 5 rectangles and when I try to list the cumulative area it says "varies" even though if I list the areas separately they all have one.
    another is an image of a single hatch for which i need to get an area. it is newly drawn and listed as associative, but when i try to get the area autocad says it has no area.
    Active Contributor
    Re: Hatch Area
    08-10-2007 10:09 AM in reply to: jshiel
    and before you ask, I have already searched the discussion groups for this problem (both 2006 and 2007) and not found an answer under area hatch, area, or cumulative area.
    I have also tried convertplines, tried saving as 2007 (our default is 2000). I have tried PE to make sure all polylines are closed, and I have not trimmed or messed with the hatches in any way. Other people at the office are able to get areas from hatches without problem, so I know it can be done.
