• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    EmilioDD
    Grip Select and Mouse pointer hangs for 2 seconds
    190 Views, 3 Replies
    02-22-2012 01:03 AM
    Good morning to you all,
    I have had the same problem with Autocad 2009LT so, I tried to downgrade to my older version of Autocad 2007 with service pack2 but the problem persists.
    I have an Acer Aspire 6930 with Nvidia GeForce 9300M GS graphic card and Windows xp.
    When I click an object to select his border e try to move it mouse pointer freezes for two second before the object really move. This problem is so annoyng and I don't know how to proceed.
    I didn't install true type fonts and graphic card hardware acceleration is at his lower value. I also tried several mouse.
    Thank you so much for your help,
                    EmilioDD
    Please use plain text.
    Re: Grip Select and Mouse pointer hangs for 2 seconds
    02-22-2012 07:00 AM in reply to: EmilioDD
    some questions to you :smileywink:
    • what object-type is the "border" you select and try to move?
    • Does this hangup apeear only in this single drawing or does that problem also exist in a new drawing (based on an original AutoCAD-template) with just one line?
    • Is you properties window open, if so does the problem persist if you close the property window?
    • what does _AUDIT report for this drawing?
    • can you upload the drawing so we can see the object of interest?
    - alfred -
    Alfred NESWADBA
    Member
    EmilioDD
    02-23-2012 12:53 PM in reply to: alfred.neswadba
    Hi Alfred,
    thank you for your question, here the answers:
    1) the object I try to move is a circle, but the same happen also with a line
    2) using a new autocad template with a single circle the problem is considerably reduces.
    3) properties window is closed
    4) the _audit command has no effects
    5) I have no problem to upload the project, but it's 40MB.
    Thank you, Emilio .
    02-23-2012 02:53 PM in reply to: EmilioDD
    That's a filesize where you'll have to think about your hardware (processor, memory and graphic-card + driver) and OS.
    What are the system-info's from your current pc/laptop?
    - alfred -
    Alfred NESWADBA
