• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Member
    Fatal Error
    233 Views, 5 Replies
    11-20-2012 03:24 PM
    In AutoCad 2008, every time I go to open a file after I already have one file open, I receive the following:
    Fatal Error: Unhandled e06d7363h exception at fdf5caedh.
    And then the program quits completely and kicks me back to the desktop. Please help me fix this problem.
    Please use plain text.
    pendean
    Re: Fatal Error
    11-21-2012 05:47 AM in reply to: NIID
    Did this problem just start, or has it always happened?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Member
    Re: Fatal Error
    11-21-2012 07:59 AM in reply to: pendean
    This problem started about a week ago.  It is very frustrating as I have standard furniture blocks that I like to copy and paste from different files and since i cannot have more than one file open, it is making this very difficult.   Any suggestions?
    -Liz
    pendean
    Re: Fatal Error
    11-21-2012 09:22 AM in reply to: NIID
    If you did not add or install any new software or AutoCAD add-ons, Windows Restore feature may be able to fix the problem if you back further than last week.
    Member
    Re: Fatal Error
    11-21-2012 09:46 AM in reply to: NIID
    How would I go about performing the wondows restore feature?
    Distinguished Mentor
    Re: Fatal Error
    11-21-2012 04:22 PM in reply to: NIID
    Shut down all programs and reboot windows into safe mode.
    To do this, hold F8 when the system starts to boot until a boot menu comes up. Select the plain safe boot mode and let the machine finish booting. Just click OK and/or YES in any dialogs that come up.
    When the machine has fully booted to the desktop , hit F1. Do a search for System Restore.
    This will give you the link or command to start the system restore process.
    You MUST have your system set up to save restore points for this to work.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
