• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    Error 1308 in installation
    763 Views, 2 Replies
    07-26-2006 10:52 AM
    When I want to install AutoCAD 2007 from CDs, it don't finish and present this error 1308.
    I copied the content from CDs to Hard drive in my computer and starting the installation from it, but don't finish for the same situation.
    How should I repair this problem?
    thanks for you help
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Error 1308 in installation
    07-26-2006 11:50 AM in reply to: JohnFredy
    Error 1308 could mean that you have a bad CD. Though it looks as though the error is pointing to a file on a network shared D drive. Verify if you have access and if the file exists.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    07-27-2006 12:49 AM in reply to: JohnFredy
    I had the same error code in the case that the installation was made from the copied source in the hard drive or a shared cd from network. This error appeared when trying to install a file that was actualy on the second cd. When I made the installation from the cd on the same computer instead of the error at that point was asking for the second cd.
    Is it a stand alone installation made from the cd of the machine that the installation takes place? Is the error occuring in the last stages of the installation when the installation fanalizes or somewhere in the middle?
