• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    Edit OLE object - how to rotate?
    913 Views, 7 Replies
    08-06-2008 08:12 PM
    Is there a way that i can rotate an OLE object on the drawing? (paper space or model space). I've tried different ways to rotate an OLE object (OLE object chart from MSExcel but not rotating). I've used the MVsetup command to change the view angle of viewport with an OLE in the model space but the OLE object stay on the same angle but other objects within the same viewport rotated. on the properties tool bar, there is no option for rotation.
    Your help will be highly appreciated.
    Please use plain text.
    *Dean Saadallah
    Re: Edit OLE object - how to rotate?
    08-07-2008 05:24 AM in reply to: SHASHIKIBUTA
    Not an option.
    Rotate outside AutoCAD then re-attach.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    New Member
    08-07-2008 03:02 PM in reply to: SHASHIKIBUTA
    Thanks for the reply Dean.
    Is there a chance for autodesk to enhance the OLE properties and add this rotating option? anyone from autodesk?
    I don't want to screw the data on graph that comes from client and it will take a while to rotate it from the MSexcel since sometimes there are more than two data to rearrange.
    *Dean Saadallah
    08-08-2008 07:31 AM in reply to: SHASHIKIBUTA
    They haven't done it yet through 2009... .
    Dean Saadallah
    Member
    11-14-2012 06:10 AM in reply to: SHASHIKIBUTA
    I'm running 2013 and it still cannot be done.  I vote for a service pack fix.
    Valued Mentor
    TerryDotson
    11-14-2012 07:52 AM in reply to: SHASHIKIBUTA
    I would use a crayon before I would use OLE.
    Member
    11-14-2012 08:01 AM in reply to: TerryDotson
    Terry, Thanks for the really useful help.  This forum is for helping people, not bashing them.  How do you even know what we're up to?  If you're pushing your add-on maybe you should make a nice sales pitch instead of just making people feel like idiots.
    Valued Mentor
    TerryDotson
    11-14-2012 02:25 PM in reply to: aaron_kaczor
    I'm not bashing anybody, unless you are a Microsoft employee in charge of Windows OLE you have no reason to be offended.   Also note my reply was to the original poster (who adequatedly explained what they are up to), not you.
