AutoCAD 2007/2008/2009 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
EDIT BLOCK ATTRIBUTE
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
377 Views, 4 Replies
08-09-2012 10:19 PM
I have two blocks in my drawing both with the same name but with different font styles. I have tried to set them both the same using BATTMAN but the text rotation changes or becomes mirrored in some.
Is there a way to do this maybe with a lisp. If so does anybody have one I could use.
Thanks.
Re: EDIT BLOCK ATTRIBUTE
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-12-2012 05:51 PM in reply to:
pendean
Thanks but ATTSYNC also appears to rotate or mirror the text. I have also played arround with BEDIT, BLOCK and -BLOCK but without sucess. I know that there are lisp routines for globally changing the attribute layer and colour etc does anyone have one for setting attribute text to the same font style for blocks with the same name blocks in a drawing.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-13-2012 03:09 PM in reply to:
KLIPIT
Hold the CTRL key down and select the individual attributes that need changing. You can select all the attributes that need modifying and do them in one go.
Now all you do is go to the properties and change the setting you want, in this case it would be the text style.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as Brad Coleman
as Brad Coleman
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-13-2012 03:38 PM in reply to:
Icemanau
Thanks Brad that does work and I think I have selected them all. Its just that its quite a busy drawing and the blocks have been pulled in from various other drawings to make a master and I was hoping for a lisp to make life easy for me. Many thanks.
