• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    DWG to PDF
    127 Views, 9 Replies
    08-15-2007 04:41 AM
    I'm looking for the best software available to convert dwg files to pdf. Thanks.
    Please use plain text.
    *Dean Saadallah
    Re: DWG to PDF
    08-15-2007 04:51 AM in reply to: dpropson
    Do you want to spend money? Look up ACROPLOT.
    You do know 2007 comes with a PDF plotter already set up, under PLOT
    command.
    Other freebies can be had through an internet search, "free PDF driver" for
    a search term.
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    Re: DWG to PDF
    08-15-2007 05:34 AM in reply to: dpropson
    Also Illustrator works fine. Open Illu, open drawing in original size and save as PDF. Note that Illu opens everything in the drawing...
    Distinguished Contributor
    Re: DWG to PDF
    08-15-2007 06:45 AM in reply to: dpropson
    You asked for the "BEST". ADOBE ACROBAT DISTILLER IMO.
    Re: DWG to PDF
    08-15-2007 07:50 AM in reply to: dpropson
    Thanks for all the insight. "BEST" for the cost... Also, easy to use.
    We have about 100 architects. We are not on 2007 exclusively yet.
    Dennis
    Re: DWG to PDF
    08-15-2007 08:02 AM in reply to: dpropson
    Our experience with ACROPLOT is that it did not handle DWGs with several XREFs involved. That is what my people found before I arrived here. I can't confirm this.
    *ddpcad
    Re: DWG to PDF
    08-15-2007 08:08 AM in reply to: dpropson
    I've been using AcroPlot for about 5 years and use a lot of XRefs. Never
    had a problem with it here ??
    Dave
    DDP
    Active Contributor
    Re: DWG to PDF
    08-15-2007 04:07 PM in reply to: dpropson
    i've only ever used the free version of PDF factory, but I always find it the best pdf software that I have used.
    *R.K. McSwain
    Re: DWG to PDF
    08-22-2007 03:56 PM in reply to: dpropson
    ddpcad said the following on 8/15/2007 10:08 AM:
    Never had a problem with Acroplot and XREFS here either.
    R.K. McSwain
    http://rkmcswain.blogspot.com
    Valued Contributor
    Re: DWG to PDF
    08-23-2007 01:41 PM in reply to: dpropson
    If you're just looking to create the odd PDF file, check out www.pdf995.com It will work with anything that shows up on plotted paper because it adds a print driver, not just a converter.
    There's an annoying sponsor message, but you can get rid of that for the $10 purchase fee. pdf995.com also has programs for editing, and security of PDF files. Message was edited by: DaOtter
