AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Copy & paste = invalid - dwg saved from Autocad 2010
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Discovered on Friday that when the 2009 user opens files saved by 2010 as 2007 & tries to copy & paste, just gets "invalid." This happens either within the same dwg or into another dwg. If he starts a new dwg or uses a dwg that 2010 has not been used in, copy & paste works fine.
Other than upgrading the 2009 to 2010 (not an option at this time), any suggestions? Thank you.
Re: Copy & paste = invalid - dwg saved from Autocad 2010
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Also tried purging dwg & still 2009 won't paste.
Thanks for your suggestions anyway.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
...also experiencing this same problem. I'm also having trouble inserting blocks. I am not enjoying my 2009 software at all.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I called my re-seller tech support about this. It's a compatability issue. If the drawing has been opened with 2010, they will need to export to autocad before someone with 2009 can open it. They said as long as you're moving files forward there should be no problems, autocad takes care of the change for you.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know this is an old thread, but I'm having this same problem in ACAD 2010. I'm saving as 2007 and when I PASTECLIP I get *invalid*. I don't have 2009 at all, only 2010, and I'm working in files that have never been opened in another version of CAD.
Frustrating...
Jason Rossitto
Beth Israel Deaconess Medical Center
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You may be pasting an AEC or 2010 object that's not allowed in 2007's format (reason you can do it in R2009 is it only has 2007 as a format).
Opening a file in 2010, regardless of your SAVE setting, will upgrade AEC content to a format not accessible in R2009 or lower. AECTOACAD command may fix all of your files.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have had a same problem.
In my perception it happanes while we try to copy object which is created by Other CAD softwares(Or custom made objects,such as hatch from Ravit). I delete costom made hatches before I copy with the base point. It worked for me.
