• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    Copy/Paste issues with 2007
    171 Views, 13 Replies
    06-13-2007 12:56 PM
    I have recently experienced a problem with copying a part from one drawing and pasting into my current drawing in ACAD 2007. The part copied from one drawing and transferring to the new drawing has a predecessor that will not go away. Each time I copy and then past into the new drawing, a previous paste item is there and will not go away after it has been utilized. I cannot override the previous past command. I have purged both drawings. Shut down and rebooted. Set up on a separate computer an into ACAD 2005 copy of ACAD and still the same thing continues to happen. Cannot eliminate the previous pasted item from the database. HELP Please
    Please use plain text.
    *Dean Saadallah
    Re: Copy/Paste issues with 2007
    06-13-2007 01:36 PM in reply to: Steve Ketcham
    what are you copying/pasting?
    what is this extra entity?
    "part" and "predecessor" are not useful terms here, use AutoCAD entity type
    names and terminology.
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    *Gehenna
    06-13-2007 02:45 PM in reply to: Steve Ketcham
    Have you tried exploding the part in the "one drawing" so that you can
    purge the "predecessor" and then copy?
    *cadanator
    06-13-2007 03:13 PM in reply to: Steve Ketcham
    Or draw(post) Dean a screen shot, he likes pictures :-p
    "Dean Saadallah" wrote in message
    news:5625484@discussion.autodesk.com...
    Dean Saadallah
    06-13-2007 05:01 PM in reply to: Steve Ketcham
    Better yet, JD likes dwg files. Zip and post.
    *Dean Saadallah
    06-14-2007 06:09 AM in reply to: Steve Ketcham
    I actually prefer dwg to pics when it's something like this... .
    Dean Saadallah
    Member
    06-14-2007 08:26 AM in reply to: Steve Ketcham
    I have not tried exploding the part that I am trying to copy/paste but will try that. I cannot get rid of the original before anything happens. It only appears to be happening in this particular drawing. I have since done the same function n another drawing and it seems to be responding fine.
    But thanks for the tip. I wil ltry that.
    Member
    06-14-2007 09:04 AM in reply to: Steve Ketcham
    Dehenna:
    That seemed to be the secret. I exploded the new object to be inserted into the other drawing after reopening the file today and it worked absolutely perfect. Dont know if that is the secret of not but it worked.
    Steve
    *Gehenna
    06-14-2007 09:31 AM in reply to: Steve Ketcham
    > Dehenna:
    > Thanks,
    > Steve
    Welcome
    Active Contributor
    06-21-2007 05:02 AM in reply to: Steve Ketcham
    Your problem is that you have a duplicate block name. The information you are pasted has a block with the same name as drawing you are trying to bring it into. Look at all the block names in the problem drawing and then look at the block names of the information you are pasting. Most likly you have a block with the same name. Rename one of them and you will be fine and will not have to explode it.
    Dennis
