• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    Convert IGS or Step to DWG
    3522 Views, 7 Replies
    08-06-2012 08:13 AM
    How do you convert IGES or STEP to DWG?
    I have IGES of one model and IGES and STEP of another.
    My 3D skills are basic, so I want to transfer them to 2D in AutoCAD then dimension.
    I recall SOLPROF can be used on a 3D model to give 2D views. Can you tell I haven't used ACAD in anger for a while?
    I have Inventor 7 and ACAD 2009.
    Thanks in advance,
    J.
    Please use plain text.
    *Expert Elite*
    Re: Convert IGS or Step to DWG
    08-06-2012 11:38 AM in reply to: motiv8j
    You can do the conversion in Inventor or free Inventor Fusion http://labs.autodesk.com or in AutoCAD 2013.
    Inventor Professional 2014 Edu 64-bit
    Member
    08-07-2012 03:12 AM in reply to: motiv8j
    nightmare!:smileyfrustrated:
    I downloaded Inventor Fusion. Only seemed to give me a DWG option, not version related.
    I then tried to open the DWG in my AutoCAD 2009. Couldn't do it, needed to download TrueView.
    I downloaded TrueView 2011, following the links from AutoCAD 2009. Tried to open the file, said "The file could not be opened as it was created with a more recent version of DWG TrueView.
    *Expert Elite*
    08-07-2012 05:43 AM in reply to: motiv8j
    Isn't there a more recent free release of TrueView (2013?) for converting files?
    What about saving as 2010 dwg to convert in TrueView 2011?
    What about saving as ACIS (*.sat) or *.dxf directly and then opening directly in AutoCAD 2009?
    *Expert Elite*
    08-07-2012 05:49 AM in reply to: motiv8j
    Is this the same link that AutoCAD 2009 sent you to?
    http://lmgtfy.com/?q=dwg+true+view+2013
    *Expert Elite*
    08-07-2012 05:52 AM in reply to: motiv8j
    What about using Inventor 7 and saving as dwg solid?
    http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
    *Expert Elite*
    08-07-2012 05:55 AM in reply to: JDMather
    How about posting your files here
    http://forums.autodesk.com/t5/AutoCAD-2013/bd-p/706
    or here
    http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
    and asking someone to do the conversion to 2007 format for you?
    That solution would require almost zero effort.
    Sleep well, sweet dreams.
    Member
    08-07-2012 06:12 AM in reply to: motiv8j
    So many options :smileysurprised:
    I'll try them and let you know which one is the easiest to execute.
    Thanks in advance,
    J.
