• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    Centerpoint object snap problems when using the polar array - Mechanical 09
    115 Views, 0 Replies
    09-22-2009 07:28 AM
    When using Polar array and trying to select a center point for my array, my snap feature stops working and I just get an orange hourglass shape instead of the normal box or x when snap is working, and it stops recognizing any mid or center or intersection points, but when I use a line or a circle or any other feature the utilizes snap, the feature works fine. To add to the confusion I was using my polar array feature and everything was working correctly, I added a dimension and then tired to use the Polar array again and then I had this problem. I don't think I accidentally hit a key or anything but I don't know what could make it act fine one minute and not the next.
    Please use plain text.
