• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    *Robert B. Price, C.Mfg.Engr.
    COMPRESSION SPRINGS
    232 Views, 7 Replies
    12-03-2009 06:04 PM
    Does anyone know of a good subroutine that will draw accurate 3D models of
    closed and ground compression springs that works in 2008. There used to be
    one that worked in 2006.
    Bob Price
    A*G*M
    Please use plain text.
    *Dean Saadallah
    Re: COMPRESSION SPRINGS
    12-04-2009 05:42 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    There was no such thing in R2006: what 3rd party add-on or routine did you
    use then? It should work in 2008 unless it was specifically compiled for
    2006.
    Elaborate, provide more details about your 2006 choices.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *Pro
    12-04-2009 06:19 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    Have you tried the HELIX command and then swept a circle along its path?
    I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
    *T Bennett
    12-04-2009 07:35 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    Doesn't AutoCAD Mechanical have this feature?
    Todd
    "Dean Saadallah" wrote in message
    news:6299433@discussion.autodesk.com...
    2006.
    Dean Saadallah
    *Dean Saadallah
    12-04-2009 07:37 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    We are not in the Mech discussion area though and the OP did not specify.
    Dean Saadallah
    12-04-2009 11:34 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    That is exactly the problem Dean - the routine I had was compiled to work in
    2006 and does not work in 2008. I think it came for EMT Software which no
    longer supports it. I would like to find the author and ask him to modify
    it so it will run on 2008. It worked very well.
    Thanks for the response
    Bob Price
    2006.
    Dean Saadallah
    *Dean Saadallah
    12-04-2009 11:54 AM in reply to: *Robert B. Price, C.Mfg.Engr.
    Inquire in the Customization area, provide them with sample dwg files and
    perhaps the name of the app/routine from the 3rd party. They might just have
    the answer you seek.
    Dean Saadallah
    12-04-2009 12:24 PM in reply to: *Robert B. Price, C.Mfg.Engr.
    Thanks Dean
    RBP
    news:6299861@discussion.autodesk.com...
    Dean Saadallah
