• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    *Tony Tanzillo
    Re: Broken
    04-10-2008 12:31 PM in reply to: *Tony Tanzillo
    Ok thanks.
    It looks like Sub-selection of 3DSOLIDs is the trigger.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2009
    Supporting AutoCAD 2000 through 2009
    http://www.acadxtabs.com
    "Jason Piercey" wrote in message news:5901087@discussion.autodesk.com...
    I do happen to be working on a job that contains
    3dsolids, so that is a good possibility but I can't
    be 100% sure.
    "Tony Tanzillo" wrote in message
    news:5901018@discussion.autodesk.com...
    You said you can replicate this, and others can't.
    Can I ask, if in the same AutoCAD session where you saw it, if you were
    working with 3DSOLIDs ?
    Please use plain text.
    *Jason Piercey
    Re: Broken
    04-10-2008 01:12 PM in reply to: *Tony Tanzillo
    For that drawing only or for the session?
    Do you have steps to reproduce it?
    news:5901090@discussion.autodesk.com...
    *Tony Tanzillo
    Re: Broken
    04-10-2008 01:49 PM in reply to: *Tony Tanzillo
    I reproduced it by just opening a file with a composite 3D solid, and doing some subselections of solids (including Fillets, which cause AutoCAD to go bonkers).
    After that, it happens in any file opened in that session.
    "Jason Piercey" wrote in message news:5901106@discussion.autodesk.com...
    Steve_Johnson
    Re: Broken
    04-10-2008 06:23 PM in reply to: *Tony Tanzillo
    > I've since learned that it doesn't happen right after a cold start.
    Hmm, that makes it particularly nasty. People will test their stuff, it will work fine, they will distribute it, then it will start failing randomly and inconsistently in use. Ugh.
    Steve Johnson
    http://www.blog.cadnauseam.com/
    Steve Johnson - blog nauseam - ClassicArray
