• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Valued Contributor
    amflasf
    BCOUNT
    173 Views, 5 Replies
    05-17-2012 11:20 AM
    BCOUNT tool is not working.
    I type it and CAD doesn't recognize it as a command.
    How do I get it back?
    Please use plain text.
    *Expert Elite*
    Re: BCOUNT
    05-17-2012 11:42 AM in reply to: amflasf
    BCOUNT is a command from the express-tools. So you haven't them installed or they are not loaded (they won't get loaded it the support-path to the ExpressTools-directory is not added).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    amflasf
    Re: BCOUNT
    05-17-2012 11:56 AM in reply to: alfred.neswadba
    The express tools pull down does show up when I have opened CAD.
    Does that mean it's loaded?
    I'll check under options and tools, but in the meantime please let me know what to do.
    Thanks!
    *Expert Elite*
    Re: BCOUNT
    05-17-2012 12:03 PM in reply to: amflasf
    That means that the menu from the express-tools is loaded, not that the tools themselfes are loaded.
    If you click to any of the commands within this menu-group and you get the message like "unknown command" then the ExpressTools are not loaded.
    >> [...] let me know what to do
    Start _OPTIONS, go to tab "Files", within the first group for support-path add one path for the express tools (you will have first to scan through your AutoCAD-installation folder that you have a folder "Express" and there are files in it).
    Check this screenshot (for 2013, so you must use your paths for 2007)
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    amflasf
    Re: BCOUNT
    05-17-2012 12:06 PM in reply to: amflasf
    Ok, so I thought I repathed the file to the correct location.
    Then I shut CAD down and restarted but BCOUNT is still not working.
    Thoughts?
    Valued Contributor
    amflasf
    Re: BCOUNT
    05-17-2012 12:10 PM in reply to: alfred.neswadba
    Ok, got it! Oddly enough it was pathed on our network and when I repathed it to the local drive it worked.
    Thanks!!!
