• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    jnelson
    Autocad 2009 will minimize to task bar but will not restore
    929 Views, 7 Replies
    06-10-2011 09:54 AM
    I have a Windows 7 64 bit system that will open and run Autodesk 9 but if the program is minimized, it will not restore unless you use Switch To from the task manager.  If you crash out of the program, an event log error shows ad32lw.exe and msvcr80.dll are at fault with error code: 0xC0000008.  A reinstall of the application did not resolve the issue.
    Does anyone have a solution or ideas on what is causing this error?
    Please use plain text.
    FarrenYoung
    Re: Autocad 2009 will minimize to task bar but will not restore
    10-17-2011 12:00 PM in reply to: jnelson
    Have you figured this out?  It is happening to me in AutoCAD 2011.
    --Farren
    If this post helps, please click the "thumbs up" to give kudos
    If this post answers your question, please click "Accept as Solution"
    *Expert Elite*
    pendean
    10-17-2011 12:52 PM in reply to: FarrenYoung
    Turning off Win7's Aero theme (go with Windows Basic Theme) seems to fix it for some users.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Distinguished Contributor
    12-16-2011 07:23 AM in reply to: jnelson
    We get this too, when we need to run Mechanical Desktop 2009.  I figure we'll never get an answer, given that MDT is now abandonware.
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
    FarrenYoung
    12-16-2011 08:02 PM in reply to: jnelson
    Hey there,
    I'm not on a machine with Autocad installed, but if I remember correctly I solved this by changing a setting that turns off grouping the open drawings on the windows taskbar.  I can't remember if the fix is to group them or ungroup them.
    Here is a thread that talks about that and how to fix it, in short, use the TASKBAR command and toggle between 1 and 0.
    http://forums.autodesk.com/t5/AutoCAD-2011/Windows-7-taskbar-switch-problem/td-p/2682761/page/2
    Good luck!
    --Farren
    Member
    xdanmeyerx
    01-05-2012 10:43 AM in reply to: jnelson
    Hi Everyone,
    I'm still getting this in Windows 7 64bit with AutoCAD 2011. I've tried Windows Classic Theme, I've tried taking off the Taskbar grouping, and it seems the only way to restore Autocad is through TaskManager.
    I have noticed that if you have more than one AutoCAD running, the second one instance is normal. Any Ideas??
    Daniel
    Member
    xdanmeyerx
    01-05-2012 11:20 AM in reply to: xdanmeyerx
    Some more information regarding symptoms:
    In Windows 7 64bit Aero Theme:
    * Alt+Tab does not restore AutoCAD 2011
    * Win+Tab does not restore AutoCAD 2011
    In Windows 7 64bit Classic Theme:
    * Alt+Tab does DOES restore AutoCAD 2011
    * Win+Tab is not supported by the Windows Classic Theme.
    In either theme:
    * Using the minimize button [ _ ] to minimize AutoCAD 2011 will cause it not be restored without Task Manager
    * Clicking on the task bar icon for AutoCAD while restored or maximized will cause it to minimize correctly and it can be restored.
    * If you launch two instances of AutoCAD, the second instance will behave normally.
    I really want to avoid writing a script to launch two AutoCADs and killing the first instance every time AutoCAD is launched :smileywink:
    Thanks again,
    Daniel
    Member
    xdanmeyerx
    01-05-2012 02:32 PM in reply to: xdanmeyerx
