• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Member
    AutoCad fatal error
    341 Views, 8 Replies
    09-26-2012 05:02 AM
    Everytime I have a file open and then try to open a new file I get fatal error: Unhandled e06d7363h Exception at 7591d36fh and AutoCad then shuts down on me.  I have sent the error report to Autodesk but have never heard anything back.  Can anyone explain to me why this is happening?
    Please use plain text.
    pendean
    Re: AutoCad fatal error
    09-26-2012 05:30 AM in reply to: tandmhomes
    Did this problem just start? or has it been going on since the year 2007?
    What changed recently, or about the time thhis problem started, on your PC? Something did change.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    09-26-2012 05:59 AM in reply to: pendean
    It has been happening on and off for about 4 months now.  As far as I know nothing has changed on my computer, I tried reloading AutoCad but that didn't fix the problem.
    Distinguished Mentor
    Moshe-A
    09-26-2012 08:59 AM in reply to: tandmhomes
    hi,
    try to open first the dwg that you get Unhandled Exception does it open?
    if it does not? you need to audit / recover it
    generally most of the problems is inside the dwg database. if after fixing it
    it still won't load? then the problem might be in AutoCAD or OS or Hardware.
    cheers
    moshe
    Member
    09-26-2012 09:44 AM in reply to: Moshe-A
    It doesn't matter what I'm opening as soon as I hit the open button I get the error, I don't get far enough to pick what file I want to open.
    Moshe-A
    09-26-2012 09:55 AM in reply to: tandmhomes
    yes but you said that this only happends in the second file you open
    or now you can open  noting?
    Moshe-A
    09-26-2012 09:57 AM in reply to: tandmhomes
    can just open AutoCAD by double clicking on AutoCAD shortcut
    without openning any file?
    09-27-2012 12:49 AM in reply to: tandmhomes
    what antivirus-software do you have? And: have you tried to disable it?
    What happens if you turn off FILEDIA (set it to 0) and try then command _OPEN and put the filename you like to open in the commandline?
    - alfred -
    Alfred NESWADBA
    Member
    09-27-2012 04:14 AM in reply to: alfred.neswadba
    I'm not sure how but I think the problem has been fixed.  Thanks for the help.
