AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCAD Version 2008 Properties
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having a problem with properties. When I left clicked an object to find out properties - It picks-up the object however as soon as I clicked the right button the high light disappears. I have attached one drawing. I was trying to find out what size font on the text so that I could scale the drawings properly. Some settings have changed on my drawings and that is not allowing to do the Properties. Can somebody help me on this?
Re: AutoCAD Version 2008 Properties
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
goto _OPTIONS and verify the right-click settings
Also: if the objects get's deselected there would be some message in the commandline, isn't there any?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did not have any need for Autocad for a month. That is why I did not respond to your suggestion. II still have the same problem. I do not get any error message. I have re-installed AutoCAD 2008 thru control Panel. I have attached screen shop of my right click setting and a typical drawing that will not deselect when I click right button. I just noticed that if Typein "Properties" in command line the Property Window opens. The right click will not let me do that.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
have you compared my screenshot and yours?
You have for the option "Edit Mode" ("If one or more objects are selected, right click means") ==> Repeat Last Command ... and not (like I have) Shortcut Menu
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I thought I have checked it. My Right-Click configuration short cut menu was not checked. Once I checked it - It is wooking. My question is how it got chaaged? Is it possible that when I receive drawings from other people that drawing causes the change?
Thanks for helping me out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, because this setting is stored locally on your machine (for your user-name), it's not depending on any drawing-files.
- alfred -
Alfred NESWADBA
