• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    New Member
    AutoCAD Frozen
    213 Views, 2 Replies
    11-18-2012 04:20 PM
    When I open AutoCAD my mouse doesn't work.  Any suggestions oother than a re-install?
    Please use plain text.
    Distinguished Mentor
    Re: AutoCAD Frozen
    11-18-2012 07:44 PM in reply to: wgc_57
    Assuming it's a USB mouse, try unplugging it and then plugging it back in to re-initialise the driver.
    If that doesn't work, Open ACAD, hit ALT-T then ALT-N. Now CTRL-TAB to the system tab and check your pointer settings. It should read "Current System Pointing Device" in the drop down box. If it doesn't, press TAB once and then the up/down arrow until it shows up. Now hit enter and you should be OK.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    *Expert Elite*
    Re: AutoCAD Frozen
    11-18-2012 10:54 PM in reply to: wgc_57
    Does it not work in the graphics-area or also not in the menu-area?
    If just not in the graphics-area of AutoCAD: have you activated SNAP? If so try to disable it using <F9>.
    If the mouse does not work anywhere in AutoCAD how did you close it? Or did you have to use the task-manager therefor?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
