• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    New Member
    Accepted Solution
    AutoCAD 2009
    378 Views, 2 Replies
    08-04-2012 10:43 PM
    I need AutoCAD 2009 for 32 bit Windows XP.The website :  http://students.autodesk.com only offers Autocad 2010-2013,but my PC doesn't support the newer versions.
    I'm an engineering student,so I really want the software.Please provide me a link for Free download of AutoCAD 2009 (32 bit) ....
    Please use plain text.
    *Expert Elite*
    pendean
    Re: AutoCAD 2009
    08-05-2012 05:49 AM in reply to: ravd0903
    Student software is free of charge but it's not offered in older versions like 2009.
    You are out of luck, I suspect you would not be able to authorize it.
    2010 versions don't require much more hardware than 2009 unless your PC doesn't really meet 2009's requirements.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    Re: AutoCAD 2009
    08-05-2012 05:47 PM in reply to: ravd0903
    How old is your computer.
    Whart are the specs?
    (I was using a 5-6 yr old 32-bit computer with 2008-2012.)
    Was it perfect, no.  Did it work. Yes.  Did it work fine.  I would say yes (for what you will need to do as long as you have 2GB RAM.)
