• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    New Member
    AutoCAD 2008 Launch Problems
    348 Views, 3 Replies
    10-18-2012 01:22 PM
    I have been running AutoCAD 2008 for several years now on Windows XP.  About 2 days ago, the shortcut no longer launched the program:  an hourglass would appear, and then nothing - no splash page, nothing in the Task Manager.  I have also gone into the files to the application in hopes that it was just a broken short cut.  No luck.
    In reviewing other posts, I found that many others have run into this with many versions of CAD and, based on their results I have tried the following to resolve it, in order:
    1.  Rolled back Windows (no big updates occurred around the time CAD stopped responding, but I tried anyways)
    2.  Repaired CAD through Windows Control Panel
    3.  Fully removed CAD through the Control Panel, deleted folders, and removed CAD files from the registry.
    4.  Turned off DEP for CAD.
    Tried running after each attempt with no success and have run out of ideas.  Anyone able to offer suggestions, short of wiping the OS and starting from scratch?
    Please use plain text.
    *Expert Elite*
    Re: AutoCAD 2008 Launch Problems
    10-18-2012 01:52 PM in reply to: bfontes
    have you tried to start with another user-account into Windows and try AutoCAD then?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    New Member
    10-18-2012 03:19 PM in reply to: bfontes
    Just tried having another user in the office log in on my computer.  CAD will open when they are logged in.
    I don't understand why my user account, as the computer (Windows) administrator, will not allow CAD to launch.  Is there a way to resolve this or will we need to have a second, CAD-specific user account on this computer?
    *Expert Elite*
    10-18-2012 10:37 PM in reply to: bfontes
    that means at least, that your AutoCAD is working, just the user-specific profile or programs started (in Windows) or applications loaded (in AutoCAD) conflicts with AutoCAD.
    One way could now be to transfer the user-specific data (for AutoCAD) and registry content from the "good account" to the "bad account".
    The other option is to start the secondary installer. I found >>>this link<<<, but make sure you do it for AutoCAD, the link shows it for Map3D, that's a little bit different in App-IDs and path-naming.
    Good luck, - alfred -
    Alfred NESWADBA
