• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    *Tony Tanzillo
    Re: $AUDIT_BAD_BLOCK_RECORD1
    07-21-2008 07:05 PM in reply to: JimNiehoff5591
    Well, sorry to say it, but I think its pretty clear that the
    problem you're having is being caused by a defect in the
    3rd party app (or less-likly, a change in an API it uses).
    You need to take that up with the publisher of the 3rd
    party app.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2009
    Supporting AutoCAD 2000 through 2009
    http://www.acadxtabs.com
    Introducing AcadXTabs 2010:
    http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
    wrote in message news:5986933@discussion.autodesk.com...
    Here is a picture of it.
    Please use plain text.
    Distinguished Contributor
    07-23-2008 01:48 PM in reply to: JimNiehoff5591
    Yeah, What is weird is that they haven't changed anything. Or as I recall someone telling me their program is the same between 2008 and 2009. It works fine with 2008.
    I've already taken it up with them.
    Thanks Tony.
    Custom Build with Win7 Pro 64Bit SP1
    Gigabyte Tecohnology Co. X79-UD3
    3.60 gigahertz Intel Core i7-3820
    16GB GSkill Ripjaw Z PC3 2133 PC17000
    PCI-E ATI FirePro V7800 2GB 256bit
    ATA SanDisk SDSSDX24 SCSI Disk Device (256 GB)
    Dell 2001FP and (2) 2407WFPHC Triple monitor setup
    Question - Are you the Common Denominator?
    08-27-2008 04:36 PM in reply to: JimNiehoff5591
    We have the same problems and we use no 3rd party apps. We are using Autocad 2009 and C3D LDC and it happens in both.
    Active Member
    02-05-2009 01:29 AM in reply to: JimNiehoff5591
    I had the same problem.
    Solution :
    Create a WBLOCK option : ENTIRE DRAWING
    02-05-2009 02:33 AM in reply to: JimNiehoff5591
    will this help?
    rename with *.lsp extension
    Member
    francccois
    08-27-2012 01:14 PM in reply to: *Tony Tanzillo
    It woked great for me.  Simple and efficient.
    Thanks.
    François
