• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    ACAD 2008 - Slow Right Click Menu
    331 Views, 5 Replies
    10-01-2012 07:32 AM
    A work colleague is having problems with a slow right click execution of any commands within autocad. It can take up to a second to execute the command or repeat a command. It seems to just hang before carrying out the command.
    Any ideas as to why this is happening?
    Please use plain text.
    Re: ACAD 2008 - Slow Right Click Menu
    10-01-2012 08:46 AM in reply to: mpc28
    how is the right-click option configured? See under _OPTIONS in tab "User preferences" ==> upper right quarter.
    To just repeat the last command, is <ENTER> or <SPACE> also as slow with command-starting?
    - alfred -
    Alfred NESWADBA
    Member
    10-01-2012 08:49 AM in reply to: mpc28
    Spoiler
    yeah its setup to open up the seperate window, but even using keyboard commands the box opens up after a delay?
    10-01-2012 08:55 AM in reply to: mpc28
    Ok, is it the opening of the context-menu that uses to much time or does it pop up fast, but then selecting an option within it is the time-wasting issue?
    What commands are these? ....that should open a box.
    What graphiccard do you have?
    Have you tried to toogle the hardware-acceleration-swith (command _3DCONFIG ==> Manual tune)?
    Does this happen also in brand new drawings (based on original AutoCAD-templates)`?
    - alfred -
    Alfred NESWADBA
    Member
    10-01-2012 09:00 AM in reply to: alfred.neswadba
    Yeah its the opening of the context menu after right clicking the mouse - seems a delay whereas its instant on my machine
    If I press enter on the keyboard instead of right clicking mouse to open the context menu
    What graphiccard do you have? Not sure? This problem never used to be there - only happened within last month or so
    Yes also happens on a brand new drawing
    Distinguished Mentor
    10-01-2012 06:35 PM in reply to: mpc28
    You could have a hardware problem that ACAD is working around, or a background task is taking up a lot of the CPU cycles.
    All of the suggestions below will require some technical knowledge. I would suggest someone from your IT department if you don't have the knowledge to do these yourself.
    First, run a virus scan  over your system. After that, try a different scanner and run another scan. Each scanner will miss different virus's.
    Next, run a scan on your HDD. You may have bad sectors in the cache area.
    Finally, try running a burn in test on your RAM as it may be having problems.
    Also check that ALL the cooling fans in your system are ok. An accounting computer here had a faulty fan (running slow) on a video card and it was throwing up various audio errors instead of video errors when trying to run the accounting software. No other symptons or problems at all.
    If everything above comes up clean or OK, then start looking at any software installed recently. It may be conflicting with ACAD. This includes any Windows updates, although that would be widely documented by this stage.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
