• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2007/2008/2009 DWG Format
    Active Member
    3D Display Issue
    279 Views, 10 Replies
    10-28-2009 12:53 PM
    I have been having display issues when working with 3D drawings. Random lines appear on objects where there shouldn't be lines. If I change a text value say from 2 to 3 the 3 will apear ontop of the 2 and the 2 will remain there until I zoom in and out. I have tryed multiple time playing with the 3d config settings and have been unable to get rid of this lines. My video card is a NVIDIA Quadro FX 1700. Im not sure if this is a video card issue or if its an issue with my 3d settings any suggestions?
    Please use plain text.
    Valued Mentor
    Re: 3D Display Issue
    10-29-2009 08:02 AM in reply to: Rich0365
    looks like a surface face or mesh and not a 3Dsolid. How did you build it?
    Active Member
    10-29-2009 10:18 AM in reply to: Rich0365
    It is a 3D solid I checked the properties. I created it by extruding rectangles and using the union and subtract commands.
    *Pro
    10-30-2009 06:03 AM in reply to: Rich0365
    Those are most likely your isolines. Look into that.
    I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
    Active Member
    10-30-2009 06:59 AM in reply to: Rich0365
    I don't believe its a problem with isolines i changed the variable to 0 then to 15 ehich had no effect. I managed to make the lines better but still not gone by disabling hardware acceleration in the 3dconfig manual tune. So this would probably mean its my video card?
    *Pro
    10-30-2009 10:50 AM in reply to: Rich0365
    Shot in the dark ..... dispsilh ?
    DJ
    *David Parker
    10-31-2009 04:07 AM in reply to: Rich0365
    Try something a bit different. Sweep your profile along a path
    of the rectangle shaped object & see of the lines
    disappear
    Dave
    style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
    Shot
    DJ
    *Pro
    11-02-2009 06:26 AM in reply to: Rich0365
    Could you post the drawing? I think the default for isolines is 4, and you can dial that down to zero. I know there's an option in 2007 to have the object display as smooth (no isolines) and that's what the image looks like to me...
    Active Member
    11-03-2009 05:48 AM in reply to: Rich0365
    I changed the Displih setting had no effect, I tryed just creating a regular cube random lines appeared still. Here is the drawing modman.
    *Pro
    11-03-2009 06:27 AM in reply to: Rich0365
    Well I didn't see any lines when I opened it. Nothing I tried could make them appear neither. Now I am stumped...could be a difference in how our graphics cards work. Does it plot out with the lines showing?
