• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2007/2008/2009 DWG Format
    Member
    2008 AutoCAD keep changing the circles to octagons.
    414 Views, 6 Replies
    02-08-2013 05:23 AM
    Please use plain text.
    *Expert Elite*
    Re: 2008 AutoCAD keep changing the circles to octagons.
    02-08-2013 05:30 AM in reply to: arv109
    run command _REGEN
    And look to the VIEWRES-command next (>>>detail<<<)
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    02-08-2013 07:15 AM in reply to: alfred.neswadba
    Thank you for the respond. I tried to follow with no change on my drawings. Could you clarfiy how I can get "VIEWERS_command next (>>>detail<<<)? What explains all of dashed lines change to solid line at same time with circles? ? Best regards, Ali
    *Expert Elite*
    02-08-2013 08:20 AM in reply to: arv109
    If you look in my previous answer I have created a hyperlink exactly to the help for command _VIEWRES, so you should read there about the command, what it does and how to start it. Just click on the ">>>details<<<"-link.
    With every regeneration all displayed objects are refreshed according to the current view. If your linetypes are set to a low value then the refresh shows it like continuous (density to high to be displayed).
    So verify how to use MSLTSCALE, PSLTSCALE and LTSCALE (systemvariables controlling how linetype-scaling is calculated in dependence to zoom-factor or annotationscale).
    - alfred -
    Alfred NESWADBA
    02-10-2013 05:11 PM in reply to: arv109
    Have you considered adding a line in the acad2008doc.lsp file. if I want to control a variable or setting, I add a line at the bottom of this file.
    (Command "viewres" "yes" "20000")
    This allows me to set the variable or setting consistently. If you have you support files on a server for everyone, it allows everyone to have the settings.
    RockyBrown
    Aluminum Ladder Co.
    *Expert Elite*
    02-10-2013 05:52 PM in reply to: RockyBrown4134
    Sorry to say, but please don't modify the ACADxxxxDOC.LSP (the one with the version number in the filename) as it is used AutoCAD-internally/reserved. You should use the ACADDOC.LSP instead.
    Look therefor to the warning >>>here<<<.
    - alfred -
    Alfred NESWADBA
    02-11-2013 04:28 AM in reply to: alfred.neswadba
    Alfred;
    I stand corrected.  Thanksw for pointing it out. We've been modifing tha acadXXXXdoc.lsp for years and we never had a problem. I never noticed the warning before. I guess we've been lucky.
    With that said, I still suggest modifying the acaddoc.lsp file to control variables and settings.
    RockyBrown
    Aluminum Ladder Co.
