AutoCAD 2004/2005/2006
Valued Contributor
Message 1 of 5 (1,163 Views)
rename anonymous blocks
1163 Views, 4 Replies
03-30-2005 10:20 PM
Has anyone got a lisp routine that can globally rename anonymous blocks. So that you can explode them or change there color
The article on AutoCAD knowledge base was not very helpful, as it did not work and only worked on one block at a time (if it ever did work)
Allan
http://www.draftsperson.net/
*Anne Brown
Message 2 of 5 (1,163 Views)
Re: rename anonymous blocks
03-31-2005 04:34 AM in reply to: allanyz
allanyz - In addition to any replies you might receive or have already received, you may find more information or responses by posting future lisp/customization related questions in the following discussion group: Web browser: http://discussion.autodesk.com/forum.jspa?forumID=130 Newsreader: news://discussion.autodesk.com/autodesk.autocad.customization --- Anne Brown Discussion Groups Administrator Autodesk, Inc. allanyz wrote: > > Has anyone got a lisp routine that can globally rename anonymous blocks. (snip)
*Tony Tanzillo
Message 3 of 5 (1,163 Views)
03-31-2005 05:44 AM in reply to: allanyz
AFAIK, you can explode anonymous blocks. There is no way to directly make an anonymous block a named block. You would need to make another block, and then change any existing insertions of the anonmous block, to reference the new named block (express tools blockreplace will do that). -- http://www.caddzone.com AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005 http://www.acadxtabs.com "allanyz" wrote in message news:14155761.1112250052764.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone got a lisp routine that can globally rename anonymous blocks. So that you can explode them or change there > color > > The article on AutoCAD knowledge base was not very helpful, as it did not work and only worked on one block at a time > (if it ever did work) > > Allan > http://www.draftsperson.net/
Valued Contributor
Message 4 of 5 (1,163 Views)
03-31-2005 02:12 PM in reply to: allanyz
I know ! i want a lisp routine that does it automatically !
Allan
Distinguished Contributor
Message 5 of 5 (1,163 Views)
03-31-2005 03:28 PM in reply to: allanyz
Hi Tony,
You can use the rename command to rename an anonymous block, but that does not accomplish the global rename the OP wants.
For the most part, I don't want the same "bottom left" insert point of anonymous blocks. But I can explode and re-block with a name and insert point of my choosing with very minimal effort. ie:
1- explode anonymous block;
2- b; (block command, enter)
3- name of my choice
- pick insert point of my choice
- select objects
- p;; (previous, enter enter)
4- check conert to block
5- check OK
Done
To the OP, this isn't global, but is pretty easy without ever having to select anything with a window or otherwise.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
