AutoCAD 2004/2005/2006
New Member
mvc_altruist
Message 1 of 7 (3,036 Views)
mbuttonpan & fillmode
3036 Views, 6 Replies
04-17-2010 12:26 AM
Every time i open new drawing or make new drawing i always have to set mbuttonpan and fillmode. I think there is a problem with my autocad default. How do i fixed these problems please help me. I will appreciate your help.. thanks!
*Dean Saadallah
Message 2 of 7 (3,036 Views)
Re: mbuttonpan & fillmode
04-17-2010 03:53 PM in reply to: mvc_altruist
You have a startup routine, or an add-on, changing those registry entries
for you. Or you have not access to your Windows Registry to edit and change.
Look up the topic of acaddoc.lsp in help in AutoCAD, and explore how to set
variables to what you want with file startup. The feature has been around
for a very long time in AutoCAD.
Dean Saadallah
http://LTisACAD.blogspot.com
New Member
mvc_altruist
Message 3 of 7 (3,036 Views)
04-17-2010 09:49 PM in reply to: mvc_altruist
I try to search these one in autocad help but i didn't found the right settings how to fixed these problems. Can you please send me other options to fix this?.. thank you for your help...
Edited by: mvc_altruist on Apr 18, 2010 4:52 AM Edited by: mvc_altruist on Apr 18, 2010 4:58 AM
*R.K. McSwain
Message 4 of 7 (3,036 Views)
04-18-2010 01:22 PM in reply to: mvc_altruist
It's the second topic that is returned here on a google search.
http://tinyurl.com/lcfqgr
R.K. McSwain
http://cadpanacea.com
New Member
AssadMTC
Message 5 of 7 (3,036 Views)
05-24-2010 07:55 AM in reply to: mvc_altruist
Dear MVC,
You are infected with a virus called "ALS.Bursted.B" (You can google it). (ex: http://www.symantec.com/security_response/writeup.jsp?docid=2005-111717-2608-99&tabid=3)
McAffee and Symantic antiviruses can detect this virus.
If you want to remove it manually:
1- Search for “acadapp.lsp” or “acadappp.lsp” (You should find it in: "HARD_DRIVE]:\Users\[USER_NAME]\AppData\Roaming\Autodesk\AutoCAD 2007\R17.0\enu\Support)
2- Delete it
3- Open “acad.mnl” in your text editor.
4- Remove the following code from the end of the file:” (load "acadapp") (princ)"
5- Remove any instance of “acad.lsp”
The new files will be fine. In the old files you should set: mbuttonpan = 1 and fillmode = 1
Regards.
Distinguished Contributor
kulfi
Message 6 of 7 (1,631 Views)
09-18-2012 12:36 AM in reply to: mvc_altruist
Actually i have seen that a acaddoc.lsp exist in the harddisk and and as well in the drawings folders Please can you protect with a sheild of this kind of virus.
thanks
Kulfi
Electronics Engineer
Pind Saudi Arabia
New Member
itdesk.fckcp
Message 7 of 7 (1,341 Views)
01-03-2013 09:23 PM in reply to: mvc_altruist
Dears,
Dont panic because of virus infection,
its just a program modification,
Kindly find the attchments and Replace in concern user Roaming user Profile folder
Thanks and Regards
Parthiban_m
Itdesk.fckcp@fivescail-kcp.com
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
