AutoCAD 2004/2005/2006
Distinguished Contributor
Message 1 of 10 (3,798 Views)
dwg trueconvert: 2007 to 2006???
3798 Views, 9 Replies
10-19-2006 02:18 AM
Has anyone ever got DWG Trueconvert to convert a 2007 dwg to 2006(2004/5/6) format? Is it supposed to? From my reading of the description it should, but there's no documentation to go with it that I could find.
It's NEVER worked for me and now it's getting more urgent.
Ha! Autodesk's own spellchecker suggests I may like to use Truelove instead of Trueconvert.
Message 2 of 10 (3,798 Views)
Re: dwg trueconvert: 2007 to 2006???
10-19-2006 03:15 AM in reply to: superfly
It works perfectly for us - no failures yet.
What exactly is or isn't happening?
*Expert Elite*
M_Hensley
Message 3 of 10 (3,798 Views)
10-19-2006 04:26 AM in reply to: superfly
There is no 2006 or 2005 format. They both use the 2004 format. In Trueconvert there is a drop-down list at the bottom left that says Convert To. From it you can select 2007, 2004, 2000 or R14.
*Dean Saadallah
Message 4 of 10 (3,798 Views)
10-19-2006 06:12 AM in reply to: superfly
2007=2007 format
2004-2005-2006=2004 format
2000-2000i-2002=2000 format
14=14 format
13=13 format
and so on... .
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Active Member
Message 5 of 10 (3,798 Views)
10-19-2006 11:20 AM in reply to: superfly
If you have to use true convert to open a 2006 dwg from 2007 why have the option of saving it as a 2004 drawing type?
Message 6 of 10 (3,798 Views)
10-19-2006 11:39 AM in reply to: superfly
Thanks for the replies.
Just nothing happens.
I would like to convert a 2007 file so that I can open it in 2006. I open trueconvert, click on 'add', browse to the file, select 'convert to 2004', click convert, and I get "current format - unknown" and "status - read error".
I tried trueconvert maybe 4 months ago for the first time and it didn't work then. I tried again last week and got the same errors as above. It looked like maybe it couldn't do 2007 files so I downloaded it again from the Autodesk site and tried again, and that's where I am at right now.
Attached is a pic what it's telling me.
*Expert Elite*
M_Hensley
Message 7 of 10 (3,798 Views)
10-19-2006 12:38 PM in reply to: superfly
You may need to recover the drawing before trying to convert.
Message 8 of 10 (3,798 Views)
10-19-2006 01:06 PM in reply to: superfly
Looking at your picture, it looks like you're using the older truconvert. This is why it doesn't recognize the 2007 format. Did you uninstall the old version before installing the one released after 2007 came out? You might try that. HTH. Ron
Message 9 of 10 (3,798 Views)
10-19-2006 02:33 PM in reply to: superfly
That did it (uninstall, download, install). Thought I'd done that already.
Thanks.
New Member
ferbo
Message 10 of 10 (3,429 Views)
05-17-2011 07:54 AM in reply to: superfly
tengo un archivo en una vercion mas actualizda y no lo puedo abrir q puedo hacer
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
