AutoCAD 2004/2005/2006
New Member
maramuresul
Message 1 of 2 (108 Views)
Working with text in AutoCAD
108 Views, 1 Replies
05-24-2013 02:20 AM
I want to know if it is possible to insert one text, in AutoCAD, multiplied. When i modify the initial text, to be modified all texts that i inserted (that are same as the initial text) in my project. For example if i write "Door" and i want to multiply this text and put in different parts of the project, i want to be able to modify this text and the others to change as initial.
Thanks.
*Expert Elite*
Kent1Cooper
Message 2 of 2 (105 Views)
Re: Working with text in AutoCAD
05-24-2013 05:54 AM in reply to: maramuresul
You can do that with a Block, though that would require a slightly greater number of steps to update all of them [double-click on one to get into the block editor, and edit the text content there, rather than just editing content of a top-level Text entity].  Or you could do it with Rtext referencing a .txt file, though that would require editing the content in that file with Notepad or equivalent, rather than inside the drawing.  Or you can use Qselect to find all Text with a specified content [in the current space, at least], and change them all at once in the Properties box.
Or, maybe the best option I can think of: a command can be defined [and probably has been already -- try a Search] that would ask the User to select a Text/Mtext entity and for the new text content, and would find and change the content of all Text/Mtext with the old content to the new content.  Does that sound like what you want?
Kent Cooper
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
