AutoCAD 2004/2005/2006
Active Member
Message 1 of 13 (887 Views)
Why does zoom command deselect objects?
887 Views, 12 Replies
03-11-2010 11:39 AM
When I select an object, then use the zoom command to zoom in, the selected object is deselected. I want to select various objects and use the zoom tool to locate them.
I am quite sure I have been able to select multiple objects and use the zoom tool at the same time. Something seems to have changed. Have I accidentally changed some configuration or option?
Any suggestions would be appreciated.
Don
Patchy
Message 2 of 13 (887 Views)
Re: Why does zoom command deselect objects?
03-11-2010 12:18 PM in reply to: Donpk123
Always worked like that, out of sight will be deselected, unless you selected them then pan.
and set your pickfirst = 1
Active Member
Message 3 of 13 (887 Views)
03-11-2010 12:36 PM in reply to: Donpk123
Thanks, Patchy, for the quick reply.
If I understand you correctly, "out of sight will be deseleted" is not quite what I'm doing.
I select an object, then as soon as I enter "Z" and hit return, the object is deselected. The problem is that I want to select a large object and add small object which is in a group of other small objects which I don't want in the selection group. So to add the single small object I have to use the zoom tool to see it clearly. When I choose the zoom tool, I've now lost the large object, although it's still visible, but now deselected. Pickfirst is set to 1.
Don Edited by: Donpk123 on Mar 11, 2010 8:38 PM
Patchy
Message 4 of 13 (886 Views)
03-11-2010 12:42 PM in reply to: Donpk123
That would be pickadd variable, set it to 1
Active Member
Message 5 of 13 (886 Views)
03-11-2010 12:54 PM in reply to: Donpk123
Pickadd was set to 1.
Have you been able to do what I describe? That is, select an object and then "Z" + "Enter". Does that object remain selected, or does it deselect?
Don
Patchy
Message 6 of 13 (886 Views)
03-11-2010 12:57 PM in reply to: Donpk123
I got it now ☺ it got deselected, I use middle button to zoom and pan and didn't run into this problem.
But if you type in command first, then 'z it will work.
Active Member
Message 7 of 13 (886 Views)
03-11-2010 01:11 PM in reply to: Donpk123
Yes, I often use the mouse wheel to zoom as well, but there are some times when you want to do a large zoom, so the zoom commands are quicker.
I can swear I've been able to use zooming while selecting multiple objects. It's a logical thing to be able to do. What if you're not using a wheel mouse with zoom capability?
Don
Patchy
Message 8 of 13 (886 Views)
03-11-2010 01:24 PM in reply to: Donpk123
May be it was before realtime and dynamic zoom was introduced, and 'z was the same as z.
*Dean Saadallah
Message 9 of 13 (886 Views)
03-12-2010 05:42 AM in reply to: Donpk123
They do deselect and still do through R2010: use a scroll wheel mouse.
Dean Saadallah
http://LTisACAD.blogspot.com
Active Member
Message 10 of 13 (886 Views)
03-12-2010 06:16 AM in reply to: Donpk123
Thanks, Dean, for clearing that up. It would have bugged me, thinking I inadvertently changed some configuration.
Don
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
