My shortcuts are no longer working (for example, "E" for erase or "L" for line). How can these be restored.?
Try a System Restore back to the uninstall of the 2012 if you can.
See if you ripped something out that should not have been.
I've had that happen when I got too aggressive with an uninstall.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I did a repair install and that didn't make any difference. Trying a re-install nowl but I can't complete it because I don't have the install CD.
My command line for starting the program is "C:\Program Files\AutoCAD 2008\acad.exe". Could this be an issue (i.e. do I need more than just the acad.exe command)?
Ah, the item that was removed when you ininstalled th 2012. Sneaky little path wasn't it?
Anything else in the Support Folder that is missing?
You should see a path to Fonts, Help, A Program Files Support Folder as well as the User Support Folder, and others that you may deem critical.
