Welcome to the Autodesk Forums!
Load it up and try. AutoCAD 2004 is a very old software for a new OS and is not designed to work in that environment.
It may work fine but then again you may jump through many hoops to get it to do so.
There is a third party software called Longbow that many here have used to get old software to work on newer OS's. Search the Forums for other thoughts on that and Google for the software.
Good luck!
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Mebedee,
Have you had a chance to load Auto CAD? I too have a ThinkPad Tablet 2. I would like to install CAD as well. I find the tablet will "Time Out" if there is a lot of graphics resources being used. I am curious how it does with 3D drafting. I am also curious about this Longbow software as the don't have a demo.
Hello
An other solution to run ANY OLD ACAD 2000-2008 software without surprise !
1) Get from somebody a VMWare (Ready to Run) with Windows 2000+SP4 and 1.0/1.5/2.0 Gb Ram assigned
2) Run this VMWare with VMPlayer ...
Bye, Pat
Patrice BRAUD
