AutoCAD 2004/2005/2006
Active Member
Dollih
Message 1 of 2 (36 Views)
Plotstyles Named <-> Colored
36 Views, 1 Replies
03-17-2005 09:46 AM
Hi there.
Our firm uses Named plotstyles, however many of our partners are using Colored plotstyles, so we have to convert their drawings to use named plotstyles. The command ConvertPlotStyles is used to convert Named plotstyle to Colored one and also to convert Colored plotstyle to Named in 2005.
Has this command changed in 2006 (smart to have two commands "ConvertToNamed" & "ConvertToColored" that ignores if the drawing is alredy in the right plotstyle) or is it not necessary to convert files to use different plotstyle anymore?
*Daniel J. Altamura, R.A.
Message 2 of 2 (36 Views)
Re: Plotstyles Named <-> Colored
03-17-2005 03:04 PM in reply to: Dollih
In 2006 the commands are CONVERTPSTYLES and CONVERTCTB. The same as before. -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "dolli" wrote in message news:3318866.1111081614875.JavaMail.jive@jiveforum1.autodesk.com... > Hi there. > Our firm uses Named plotstyles, however many of our partners are using > Colored plotstyles, so we have to convert their drawings to use named > plotstyles. The command ConvertPlotStyles is used to convert Named > plotstyle to Colored one and also to convert Colored plotstyle to Named in > 2005. > Has this command changed in 2006 (smart to have two commands > "ConvertToNamed" & "ConvertToColored" that ignores if the drawing is > alredy in the right plotstyle) or is it not necessary to convert files to > use different plotstyle anymore?
