Hi
Not sure if this is possible or whether there maybe an easier way to achieve the same result. I have produced a dynamic block with block properties which contains a rectangle 700mm deep x 250mm wide rising up in 50mm increments to 2000mm. Each increment/size has its own manufacturing reference code. Is there a way to link the chosen size lets say 700mm x 2000mm to a attribute tag named size so when I exract the data to excel it states the correct size selected? rather than having to do it manually in the properties box.
I attach a drawing which may help explain better
Many thanks
Visibility state wont help me as my blocks are already very complicated and to produce these 4 times as a visibility would be extremely differicult.
