AutoCAD 2004/2005/2006
Active Contributor
ds_mother
Message 1 of 10 (95 Views)
Insertion of Blocks
95 Views, 9 Replies
12-26-2006 07:31 AM
Hello
How can I easily change the insertion point of a block that is already created?
Thank you so much!
*None
Message 2 of 10 (95 Views)
Re: Insertion of Blocks
12-26-2006 09:05 AM in reply to: ds_mother
ds_mother wrote:
> Hello
> Thank you so much!
Blocks are dwgs. Open the dwg(s) and then type "base" (without the
quotes). Autocad will tell you the EXISTING base (insertion) point and
all you have to do is type the new point you want. Then when you
re-insert the block, you will have a new insertion point and if you have
any blocks that had been inserted previously, they will all be updated.
Active Contributor
ds_mother
Message 3 of 10 (95 Views)
12-26-2006 10:10 AM in reply to: ds_mother
Thank you !!
*Warren Trost
Message 4 of 10 (95 Views)
12-26-2006 10:40 AM in reply to: ds_mother
Or move the objects to 0,0.
"None" wrote in message
news:5435287@discussion.autodesk.com...
ds_mother wrote:
> Hello
> created?
> Thank you so much!
Active Contributor
ds_mother
Message 5 of 10 (95 Views)
12-26-2006 11:57 AM in reply to: ds_mother
When I created the blocks in 2006, I typed in B to create a block definition. I can't find any drawings. Thanks
*Warren Trost
Message 6 of 10 (95 Views)
12-26-2006 01:10 PM in reply to: ds_mother
Also you might look into REFEDIT/REFCLOSE/REFSET.
wrote in message news:5435394@discussion.autodesk.com...
Distinguished Contributor
madcadd
Message 7 of 10 (95 Views)
12-26-2006 02:35 PM in reply to: ds_mother
Sorry mother, but none don't know none and Warren is learning from him. ;-)
Actually they are right if you are inserting a "dwg" as a block. That is NOT what you are doing. You created your block right here in the dwg you're in and just want to change the insert point.
Two ways to do it:
1) explode the block and redefine it with the desired insert point.
2) use the Refedit command to gain access to your block and literally move everything to a new location, then refclose and the insert point will stay the same, but all the geometry has moved.
I prefer number 1 above as it is so much simpler and quicker.
*Bill DeShawn
Message 8 of 10 (95 Views)
12-26-2006 10:49 PM in reply to: ds_mother
The old way was to
1. draw a line from the point that you want to be the insertion point.
2. EXPLODE the block.
3. Use the Block command
4. Type in the name of the block
5. Click on "Select objects" and type "P" for "previous" selection. Do not
select the new line.
(Whenever you explode a block, the objects within become the previous
selection.)
6. Click on "Pick Point" and select the first endpoint of the new line.
7. Click OK to finish the redefinition of the block
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
(website link works now)
Active Contributor
ds_mother
Message 9 of 10 (95 Views)
12-27-2006 06:07 AM in reply to: ds_mother
Thanks Madcadd, it worked fine. Mother
*Jane
Message 10 of 10 (95 Views)
01-01-2007 10:46 PM in reply to: ds_mother
Hsh BlockManager can insert blocks with different insert points. While
dragging before insertion, you can change the insert point. HTH
Jane
http://vanabc.com/hshsoft/
http://www.hshsoft.com
CurveTool
Hsh Block Manger
Hsh STL Importer/Exporter
wrote in message news:5435261@discussion.autodesk.com...
Hello
created?
Thank you so much!
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
