AutoCAD 2004/2005/2006
New Member
arun.green
Message 1 of 5 (2,031 Views)
Draw Slope lines
2031 Views, 4 Replies
06-23-2005 09:13 PM
Friend,
In my Diagram, the lines are always drawn in straight lines & 50 degree angles (from horizontal ). Presently I draw a horizontal line and rotating it to 50degree. but this consumes time. Giving angle while drawing the line also not a fast one(ie,for eg. @500<50). Is there any method to track my lines in vertcal and 50 degree to horizontal always.?
Thanking you,
Arun
Valued Contributor
allanyz
Message 2 of 5 (2,031 Views)
Re: Draw Slope lines
06-24-2005 12:34 AM in reply to: arun.green
Try this trick:
UCS
Z
50
then you can use ortho.
To change back go: UCS World
Allan
AutoCAD Freebies
Drafting and CAD forums
http://www.draftsperson.net/
New Member
arun.green
Message 3 of 5 (2,031 Views)
06-24-2005 04:25 AM in reply to: arun.green
Dear Allan,
It didn't help me. the problem is when I set ucs Z into 50 degrees & ortho, after the sloped line instead of going vertical the lines goes perpendicular to the first line. Please see the attachment, if my issue is not clear for you.
Thank you for your response
Arun
Distinguished Mentor
skintsubby
Message 4 of 5 (2,031 Views)
06-24-2005 04:56 AM in reply to: arun.green
Not sure if it's the solution you're after.
Turn on POLAR TRACKING. and set the angles to what you require.
Mark G
Distinguished Contributor
Tom Smith
Message 5 of 5 (2,031 Views)
06-24-2005 06:19 AM in reply to: arun.green
Draw the line at the 50 angle. Polar tracking is an easy way to do it. The older method, from before polar tracking, is to use relative polar coordinates:
Command: LINE
Specify first point: 0,0
Specify next point or [Undo]: @12'<50
This draws a line from 0,0 to a point 12 ft away along a 50 degree angle.
Look in the user's guide for various methods of entering 2D points.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
