AutoCAD 2004/2005/2006
Valued Contributor
rlantzjr
Message 1 of 15 (1,888 Views)
DLL - An attempt was made to load a program with an incorrect file format
1888 Views, 14 Replies
08-12-2005 01:13 PM
I get this message "DLL - An attempt was made to load a program with an incorrect file format" when i try to start up Autocad, Inventor, or Mechanical Desktop when i first boot up my computer. Once i just click "ok" then my toolbars are gone. I keep restarting the program and eventually i get all my toolbars and i wont see the error until i reboot my system. I am running Windows XP 64-bit (with a 64-bit processor) if that has anything to do with it? Anyone know of what may be causing this problem or how i can solve it? I did try to do a repair, but didnt seem to help.
Autodesk Inventor 2011 Certified Associate
New Member
godzilla
Message 2 of 15 (1,879 Views)
Re: DLL - An attempt was made to load a program with an incorrect file format
02-08-2006 05:47 AM in reply to: rlantzjr
I get the same error for all AutoCAD's (2006, Mechanical, Inventor). After the errors, none of the menus will load, even manually without generating another dll error. Restarting the program as you described showed no improvement for menu loading.
I have a 64 bit Opteron system running Windows XP 32 bit.
I have upgraded to .NET 2.0 which HAD NO EFFECT...
New Member
Drunik
Message 3 of 15 (1,879 Views)
03-02-2006 11:33 AM in reply to: rlantzjr
I have similar problem too! What do I ghave to do?! I get same errorfor 3ds MAX8.
I have a 64 bit Opteron system running Windows XP 32 bit SP2.
achapin
Message 4 of 15 (1,880 Views)
07-31-2006 09:52 AM in reply to: rlantzjr
I'm having the same issue. AutoCAD, Mechanical and Arch Desktop. Running XP Pro. Anyone know what could be causing this?
New Member
BaDbOy247
Message 5 of 15 (1,879 Views)
08-20-2006 08:56 PM in reply to: rlantzjr
yes i have the same problem .does anyone reply to these questions?? i need someone to resolve these problems plz
Active Member
dsekusak
Message 6 of 15 (1,879 Views)
08-20-2006 11:15 PM in reply to: rlantzjr
Same here. It is not very comfortable to work without menus and toolbars.
Please, somebody help me !
Using MDT 2007.
Not happening in Inventor, only MDT.
Member
AnnDee
Message 7 of 15 (1,879 Views)
09-04-2006 06:05 PM in reply to: rlantzjr
I've experienced the same error.
http://discussion.autodesk.com/thread.jspa?messageID=5317355⋫
Distinguished Contributor
Maneswar_Cheemalapati
Message 8 of 15 (1,880 Views)
09-10-2006 06:58 PM in reply to: rlantzjr
See if this helps... running it shouldn't matter because it's supposed to be loaded.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5590351&linkID=2475323
Maneswar Cheemalapati [3dsmax FA]
New Member
rich67801
Message 9 of 15 (1,879 Views)
09-24-2006 10:26 PM in reply to: rlantzjr
I'm solve
http://discussion.autodesk.com/thread.jspa?messageID=5339463祇
Solution
This issue occurs because the msxml3.dll file has been unregistered.
To register this file in Windows
1. On the Start menu (Windows), click Run.
2. In theRun dialog box, enter regsvr32 msxml3.dll and click OK.
jejejejejee
Member
AnnDee
Message 10 of 15 (1,879 Views)
09-25-2006 04:35 AM in reply to: rlantzjr
Unfortunately, this did not work. :smileysad:
Announcements
Need installation help?
