AutoCAD 2004/2005/2006
Member
robsand
Message 1 of 21 (12,747 Views)
Autocad 2004 and Windows 7 compatibility in XPM mode?
12747 Views, 20 Replies
10-05-2009 09:54 AM
Does anyone know If I buy a new Windows 7 machine in the near future will I be able to install Architectural Desktop 2004 using the new OS's XP Mode? If yes, would this old program also be compatible with a 64 bit machine? Thanks in advance. Rob
*Dean Saadallah
Message 2 of 21 (12,748 Views)
Re: Autocad 2004 and Windows 7 compatibility in XPM mode?
10-05-2009 11:11 AM in reply to: robsand
FYI, only top end versions of Win7 will come with that XP feature.
Dean Saadallah
http://LTisACAD.blogspot.com
Member
robsand
Message 3 of 21 (12,748 Views)
10-06-2009 07:44 AM in reply to: robsand
I understand that the upper end Windows 7 only has the XPMode. Say the XPM works for the old program, will the autocad 2004 work on a 64 bit machine? Rob
*Dean Saadallah
Message 4 of 21 (12,748 Views)
10-06-2009 03:09 PM in reply to: robsand
Most likely not, but look around here and see if anyone got 2004 to run in
any 64bit OS.
Dean Saadallah
*Expert Elite*
DarrenP
Message 5 of 21 (12,748 Views)
10-13-2009 02:58 PM in reply to: robsand
better read this before you try it because you need have hardware virtualization on your processor
http://www.microsoft.com/windows/virtual-pc/download.aspx Edited by: DarrenP on Oct 13, 2009 3:00 PM
New Member
NJCad
Message 6 of 21 (12,748 Views)
10-28-2009 05:53 PM in reply to: robsand
I just installed today (10/28/09) Autocad 2004 on Windows 7 Ultimate 32 bit. It works fine. Not sure about the 64 bit.
Member
Archibald
Message 7 of 21 (12,748 Views)
10-29-2009 08:14 AM in reply to: robsand
Today I installed my new PC with Windows 7 64-bit and the WindowsVirtualPC which then works like a Windows XP. After that, I installed within the virtual PC the AutoCAD2004 and it seems to work fine, I could open my files.
good luck to you
Archibald
New Member
mwhite4823
Message 8 of 21 (12,748 Views)
11-01-2009 04:54 PM in reply to: robsand
I just installed Windows 7 Ultimate 64 bit over VISTA 64 bit, then the Virtual PC and the XP Mode. I installed AutoCAD 2004 in the XP Mode window with no errors, but when I went to run it, AutoCAD couldn't find my license. Did you install it differently?
New Member
ppalmer
Message 9 of 21 (12,748 Views)
04-06-2010 01:03 PM in reply to: robsand
We haven't tried loading autocad 2004 on windows 7 yet, but we do have acad 2004 running on a 64bit Win XP.
Member
davidbell1
Message 10 of 21 (12,139 Views)
08-11-2010 09:57 AM in reply to: robsand
I was able to get Autocad 2004 set up with Win 7 (64 bit) XP mode, and it seems to run fine with one annoying exception.  There are two mouse pointers - one the typical AC crosshairs and then a standard mouse arrow, which I assume is the Win 7 mouse, and one lags behind the other.  Very distracting - anyone have a fix for this?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
