AutoCAD 2004/2005/2006
Member
robsand
Message 11 of 21 (5,856 Views)
Re: Autocad 2004 and Windows 7 compatibility in XPM mode?
10-04-2010 02:38 PM in reply to: robsand
I can confirm that autocad 2004 installs and works natively on regular and pro version of windows 7 (64 bit) without the need of XP modes.  Rob
New Member
cartermr321
Message 12 of 21 (5,761 Views)
10-15-2010 05:42 AM in reply to: robsand
I have been running 2004 on Windows 7 64 bit machine for about 5 months now.  I have only one problem with it.  About 30% of the time when I hit the open button it crashes with a fatal error, and I have to re-launch ACAD.  It is annoying, but I just always hit save before open, and I haven't lost any work.
Does anyone know if a patch exists for this?
Valued Contributor
jfdemars
Message 13 of 21 (5,530 Views)
11-06-2010 10:39 AM in reply to: davidbell1
Hi David,
I am thinking of doing the same as you have. Did you find a fix for your problem (There are two mouse pointers - one the typical AC crosshairs and then a standard mouse arrow, which I assume is the Win 7 mouse, and one lags behind the other.)
Also what version of Windows 7 are you running.
John DeMars
Member
davidbell1
Message 14 of 21 (5,502 Views)
11-08-2010 06:14 AM in reply to: robsand
I did not find a fix for the double mouse arrow problem with XP mode.  However, I was able to get ACAD to work natively with Win 7 64 bit.  It crashes some, and flashes an error message every time I close the program, but it is much less annoying than the two mouse arrows.
Valued Contributor
jfdemars
Message 15 of 21 (5,497 Views)
11-08-2010 08:05 AM in reply to: robsand
Thank you!!
Valued Contributor
jfdemars
Message 16 of 21 (5,489 Views)
11-08-2010 08:46 AM in reply to: robsand
How often is often: once a day, twice a day, once a week, once an hour.....?
Thanks again!
Member
davidbell1
Message 17 of 21 (5,484 Views)
11-08-2010 09:02 AM in reply to: robsand
If you were replying to me about the crashing, it has only crashed completely two times, but I do get the error messages every time it closes.
New Member
jmrivas
Message 18 of 21 (5,416 Views)
11-11-2010 09:15 PM in reply to: robsand
Have you had any problems with your Autocad 2004 in native Windows 7 64bit?
New Member
gppa
Message 19 of 21 (1,149 Views)
08-02-2013 11:58 PM in reply to: robsand
I tried to install my licensed copy of Architectural Desktop from the original install disks directly into Windows 7 P 64 bit, but it showed a text file of the setup.exe file and I didn't know how to work around this .
So I went thru a long process of installing Virtual PC and Windows XPmode.
It then did allow me to install ADT2004, but it's a hassle getting into it and can be accidentaly closed very easily.
Does anyone know how to work around this install problem so I can work in ADT2004 directly in Windows Pro 64 bit
*Expert Elite*
pendean
Message 20 of 21 (1,138 Views)
08-03-2013 07:23 AM in reply to: robsand
There is a third party tool called Longbow that claims to help older Autodesk software to install in newer Windows versions: find it and try it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
