AutoCAD 2004/2005/2006
Message 1 of 3 (959 Views)
Align multiple single line text objects
959 Views, 2 Replies
11-28-2007 02:50 PM
how can I align multiple single line text on a vertical plane?
Active Contributor
Message 2 of 3 (959 Views)
Re: Align multiple single line text objects
11-28-2007 07:54 PM in reply to: hugofp
G'day,
Select the text and in the Properties palette, change the "Position X" value to what you want. Type the value instead of picking a point.
Cheers
Distinguished Contributor
Message 3 of 3 (959 Views)
11-30-2007 11:55 AM in reply to: hugofp
What are you doing/not doing that you cannot? Can you not pick a line of text from its justification point? Can you not use this point to "track" from another line of text at it's justification point? Do you not know the height of your text if you want the multiple lines of text equally spaced like a paragraph? Can you not draw a line, in which to align all text to, by their respective justification points? Do you not know how to use the align command? Can you not use the margin and ruler in the text editor? Do you not know AutoCAD very well or drafting?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
