AutoCAD 2004/2005/2006
Active Member
laurenpope89
Message 1 of 6 (410 Views)
'ALIGN' command
410 Views, 5 Replies
01-22-2008 07:49 AM
Before my computer at work broke I was using AutoCAD 2005 and had a command called 'ALIGN' this ment I could align points parallel to others.(2D) This tool came in very handy for aligning xref to the correct position.
Now I am using AutoCAD 2004 and it doesn't seem to have this command. Is it hidden somewhere or is there any way to create new commands?
Any help would be great thanx :smileyhappy:
Lauren
*Aug
Message 2 of 6 (410 Views)
Re: 'ALIGN' command
01-22-2008 07:56 AM in reply to: laurenpope89
I use it all the time in 2004.
Aug
wrote in message news:5826686@discussion.autodesk.com...
Lauren
Active Member
laurenpope89
Message 3 of 6 (410 Views)
Re: 'ALIGN' command
01-22-2008 08:01 AM in reply to: laurenpope89
When I type in ALIGN to the command line it says :
Unknown command "ALIGN". Press F1 for help. ??
*Aug
Message 4 of 6 (410 Views)
Re: 'ALIGN' command
01-22-2008 08:16 AM in reply to: laurenpope89
It prompts me to select objects,.........
Aug
wrote in message news:5826698@discussion.autodesk.com...
*Dean Saadallah
Message 5 of 6 (410 Views)
Re: 'ALIGN' command
01-22-2008 11:17 AM in reply to: laurenpope89
Are you using full AutoCAD2004, or LT2004? It's not found in the latter... .
Are you using full AutoCAD 2004 with a custom menu, or the default AutoCAD
menu file? MNL file may not have been copied if the former is true.
I would ask the person that downgraded you if you don't know the answers for
sure, bet they have a fix.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
*Bill DeShawn
Message 6 of 6 (410 Views)
Re: 'ALIGN' command
01-25-2008 09:59 PM in reply to: laurenpope89
My AutoCAD 2004 disk got ruined, so I can check on this myself.
In AutoCAD 2006, it's not a LISP routine. Just wondering, If you open
ACAD.MNL:
(startapp "notepad" (findfile "acad.mnl"))
can you search for and find the following text?:
(defun c:align
Does the following work?
(command "_.align")
If it does, It's not a LISP routine, but a core command. I know the first
ALIGN was a LISP routine, but I don't remember at what point it became an
actual command.
_________________________
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
"Dean Saadallah" wrote in message
news:5827082@discussion.autodesk.com...
Dean Saadallah
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
