AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
tables made in 2006
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
75 Views, 4 Replies
07-13-2005 01:47 PM
I am trying to implement the facility of creating tables in 2006 but since we have various AutoCad versions (2002, 2004, 2005 and 2006) at the office, these is becoming more a problem than a solution.
When I opne a file made in 2006 with a table in paper space, 2002 simply does not open. I have looked for service packs, object enablers and so on but unfortunetaly nothing is showed.
When I open in 2004, I tried to do some arrangins. Copied the table in model space and it is viewed beautifully. But when I try to bring it into our standardization - to draw tables in paper space (bring it form model with change space), it crashes, I mean, the table is not showed.
So I wonder if there´s anyway Autodesk think about companies that need to send their files to other companies (as dwg) and make this new facilities good for all.
Thank you!
Carol
Thank you!
Carol
*Dean Saadallah
Re: tables made in 2006
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-13-2005 06:34 PM in reply to:
caca
Batch Drawing Converter works and is free from AutoDesk.
For internal use, upgrade your remaining 2002 soon, in the meantime, refrain
from using items not stock in the far-lower versions if you have to... . We
all have a mix, it's best if you always try not to be a format version
behind though after three releases, that's too much of a variation in a
single office IMHO.
For external sharing, EXPLODE all none 2004/5/6 content, or just don't use
upgraded content in those projects.
Other solutions from outside autodesk exist too.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
single office IMHO.
Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-14-2005 06:31 AM in reply to:
caca
Hi Dean,
Unfortunately Batch converter did not work. Can I be doing anything wrong?
Thank you,
Carol
Thank you,
Carol
*Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-14-2005 08:08 AM in reply to:
caca
Are you using fields in your tables?
Dean Saadallah
Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-15-2005 11:47 AM in reply to:
caca
Yes, simple numbers and texts.. No formulas or anything more complicated.
