AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
rotate3d error
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
59 Views, 5 Replies
12-31-2004 07:56 AM
I'm getting an ARX error when I use the rotate 3d command. Any ideas??
*Tracy W. Lincoln
Re: rotate3d error
Options
- Highlight
- Email to a Friend
12-31-2004 08:48 AM in reply to:
chad_cooksey
DEMANDLOAD set to 3?
Do you have a "Working Support Search Path" to the correct version?
Do you have a "Working Support Search Path" to multiple or an older
versions?
Options > File Tab + Working Support Search Path
Then check to see if there are more than one of the offending ARX files...
otherwise possibly you need to run a repair install.
Tracy W. Lincoln - TLConsulting
Autodesk Discussion Group Facilitator
"chad_cooksey" wrote in message
news:32310753.1104508643883.JavaMail.jive@jiveforu m2.autodesk.com...
Re: rotate3d error
Options
- Highlight
- Email to a Friend
12-31-2004 09:02 AM in reply to:
chad_cooksey
demandload was set wrong. thank you!!!
Re: rotate3d error
Options
- Highlight
- Email to a Friend
01-01-2005 12:38 PM in reply to:
chad_cooksey
Hi chad,
If you change your UCS planer to your view or have UCS follow on, then 2D rotate works all the time as it rotates around the Z axis. Then you never have to look to see if its the X, Y or Z axis you want. It's always the Z.
If you don't have follow on and just change your UCS planer (as I usually do) then UCS previous when you're done returns your UCS to where you were.
P.S. No bother about the demandload setting either.
Re: rotate3d error
Options
- Highlight
- Email to a Friend
01-02-2005 06:54 PM in reply to:
chad_cooksey
Isn't it about time that this command moved out of lisp and gave it better API exposure? I mean the angle reference for rotation is really convoluted. It should be transformed from a plane normal to the axis of rotation instead of the current UCS.
As a matter of fact, rotate3D, mirror3D and 3Darray should be arguments to the main commands.
Re: rotate3d error
Options
- Highlight
- Email to a Friend
01-03-2005 06:38 AM in reply to:
chad_cooksey
si si......., I agree!
