AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
rename anonymous blocks
Options
- Highlight
- Email to a Friend
556 Views, 4 Replies
03-30-2005 10:20 PM
Has anyone got a lisp routine that can globally rename anonymous blocks. So that you can explode them or change there color
The article on AutoCAD knowledge base was not very helpful, as it did not work and only worked on one block at a time (if it ever did work)
Allan
http://www.draftsperson.net/
Allan
*Anne Brown
Re: rename anonymous blocks
Options
- Highlight
- Email to a Friend
03-31-2005 04:34 AM in reply to:
allanyz
allanyz -
In addition to any replies you might receive or have already
received, you may find more information or responses by posting
future lisp/customization related questions in the following
discussion group:
Web browser:
http://discussion.autodesk.com/forum.jspa?forumID= 130
Newsreader:
news://discussion.autodesk.com/autodesk.autocad.cu stomization
Anne Brown
Discussion Groups Administrator
Autodesk, Inc.
allanyz wrote:
> Has anyone got a lisp routine that can globally rename anonymous blocks. (snip)
*Tony Tanzillo
Options
- Highlight
- Email to a Friend
03-31-2005 05:44 AM in reply to:
allanyz
AFAIK, you can explode anonymous blocks.
There is no way to directly make an anonymous
block a named block. You would need to make
another block, and then change any existing
insertions of the anonmous block, to reference
the new named block (express tools blockreplace
will do that).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005
http://www.acadxtabs.com
"allanyz" wrote in message
news:14155761.1112250052764.JavaMail.jive@jiveforu m1.autodesk.com...
> color
> Allan
Options
- Highlight
- Email to a Friend
03-31-2005 02:12 PM in reply to:
allanyz
I know ! i want a lisp routine that does it automatically !
Allan
Allan
Options
- Highlight
- Email to a Friend
03-31-2005 03:28 PM in reply to:
allanyz
Hi Tony,
You can use the rename command to rename an anonymous block, but that does not accomplish the global rename the OP wants.
For the most part, I don't want the same "bottom left" insert point of anonymous blocks. But I can explode and re-block with a name and insert point of my choosing with very minimal effort. ie:
1- explode anonymous block;
2- b; (block command, enter)
3- name of my choice
- pick insert point of my choice
- select objects
- p;; (previous, enter enter)
4- check conert to block
5- check OK
Done
To the OP, this isn't global, but is pretty easy without ever having to select anything with a window or otherwise.
- select objects
5- check OK
Done
