AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
properties palette will not justify text
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
111 Views, 4 Replies
10-21-2008 05:03 PM
somehow my properties palette has lost the justify text section
anyone know how that can happen?
is there anyway to write over the properties palette in the program with a new file?
thank you
lgs
thank you
lgs
*Dean Saadallah
Re: properties palette will not justify text
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2008 04:54 AM in reply to:
lgs663
You are not selecting text perhaps?
Dean Saadallah
http://LTisACAD.blogspot.com
Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-29-2008 11:39 AM in reply to:
lgs663
somehow my properties palette has lost the justify text section anyone know how that can happen? is there anyway to write over the properties palette in the program with a new file? thank you lgs
Gosh Dean, maybe you could have answered the question as posted, i'd bet the user is very familiar with what a text entity is. look at the depth of the question, thanks for nothing, sir
i too have the same issue as lgs, the justify text area in the properties pallet just vanished..it was a very useful part of my tool arsenal. i have used the justifytext command in the express tools, at command prompt and from the text tool bar, but miss the fact that the text moved after being rejustified.
acn
acn
*Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-29-2008 01:10 PM in reply to:
lgs663
Someone is a little grumpy.
Since it's not gone anywhere in R2006 for most, you either did something or
need to reinstall.
Dean Saadallah
need to reinstall.
Dean Saadallah
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-24-2011 11:09 AM in reply to:
lgs663
I realize this was posted some time ago, so that your problem may no longer be pertinent, but I wanted to let you know I was having a similar problem in v2006 and I found the solution elsewhere in the forums. For me, the properties palette was no longer showing a variety of information. Speicfically, when I selected a block with attributes, the insertion point, scale, block name, and attribute values were no longer there! They were listed with the command "LI" ... Anyway, the solution is to repair the registryfrom the control panel. Go to "Add or Remove Programs," find AutoCAD in the list and select "Remove," then you can select to repair the registry....
