AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
offset using 'cal
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
251 Views, 10 Replies
03-08-2007 01:53 PM
I have used 'cal in the offset command to offset distances such as 4.25/2 in the past with no problems but now in autocad mech. 2006 the answer 2.125 calculates but does not go into <2.125> for the offset value. Any idea why not?
*Gehenna
Re: offset using 'cal
Options
- Highlight
- Email to a Friend
03-08-2007 02:34 PM in reply to:
robert_chrismer
You said "calculates but does not go into <2.125>! Not sure how it does
but doesn't - try putting your computation inside parens, i.e., (4.25/2)
Options
- Highlight
- Email to a Friend
03-08-2007 04:06 PM in reply to:
robert_chrismer
>now in autocad mech
Wrong forum
http://discussion.autodesk.com/adskcsp/index2.jspa ?categoryID=14&discommunity=mfg
What happens if you use _offset instead?
Wrong forum
*Josh
Options
- Highlight
- Email to a Friend
03-08-2007 05:14 PM in reply to:
robert_chrismer
I often do the same thing you're doing for offset distances but I don't use
CAL. 4.25/2 for me would be 425/200. Since AutoCAD won't tolerate decimals
in fractions I simply add zeros where appropriate to make up for the decimal
places that I remove. I find this quicker than using CAL. Give it a try.
Josh
wrote in message news:5512771@discussion.autodesk.com...
not?
Josh
not?
*Gehenna
Options
- Highlight
- Email to a Friend
03-08-2007 06:13 PM in reply to:
robert_chrismer
> Josh
> not?
He was using the transparent command 'cal in the middle of offset
command and he needed only 2.125 - not 212.5. Works quite well - most of
the time.
> Josh
> not?
the time.
Options
- Highlight
- Email to a Friend
03-09-2007 06:58 AM in reply to:
robert_chrismer
The problem is the command offset in AutoCAD Mechanical actually does a command amoffset.
*Bill DeShawn
Options
- Highlight
- Email to a Friend
03-09-2007 07:05 AM in reply to:
robert_chrismer
Good point. However, 'Cal should work. It works on my computer. Even
without parenthesis. If 'CAL doesn't work, he can use lisp.
Command: o OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <0.3333>: (* 4 2)
8
By the way, I sure like the Erase and Layer options here.
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
(website link works now)
"Josh" wrote in message
news:5512966@discussion.autodesk.com...
Josh
not?
Command: o OFFSET
8
Bill DeShawn
"Josh"
Josh
not?
*Bill DeShawn
Options
- Highlight
- Email to a Friend
03-09-2007 07:08 AM in reply to:
robert_chrismer
That being the case, he needs to use .OFFSET with a dot in front of the
command. The underscore is for International versions to use the English
version of the command.
Bill DeShawn
wrote in message news:5513463@discussion.autodesk.com...
command amoffset.
Bill DeShawn
command amoffset.
Options
- Highlight
- Email to a Friend
03-09-2007 07:10 AM in reply to:
robert_chrismer
thanks to the on-line help, I had enough clues to figure out the problem. I was using amoffset instead of the regular offset command. Regular offset will work with the 'cal to enter in a value into the . I changed the alias in the pgp file so that I access the regular old offset rather than the new and "improved" mechanical version. Life is good again.
*Josh
Options
- Highlight
- Email to a Friend
03-09-2007 07:58 AM in reply to:
robert_chrismer
Riiiight...
First, I know he's using 'CAL. I know it's transparent. I can read.
Second, I offered him an option that isn't based in lisp and therefore will
work on amoffset...not that I even needed to know that from the OP.
Third, I'm not sure where you learned math but 425/200 does NOT equal 212.5.
Go ahead...get your calculator out and try it.
Thanks for playing!
the time.
Thanks for playing!
the time.
