• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    dimension hook
    102 Views, 6 Replies
    12-22-2006 11:33 AM
    Is there a command that eliminates the hook on dims?
    Please use plain text.
    *Bill DeShawn
    Re: dimension hook
    12-22-2006 08:46 PM in reply to: apojoe69
    Please explain further.
    Bill DeShawn
    bdeshawn@nospamsterling.net
    http://my.sterling.net/~bdeshawn
    (website link works now)
    wrote in message news:5434394@discussion.autodesk.com...
    Re: dimension hook
    12-27-2006 06:13 AM in reply to: apojoe69
    enter quick leader. pull leader & right click to "enter mtext". enter & right click. hook is the short horizontal line just before the text. setvar or command to eliminate this hook altogether?
    Distinguished Contributor
    Re: dimension hook
    12-27-2006 11:57 AM in reply to: apojoe69
    qleader > settings > play around with the number of leader segments.....
    Re: dimension hook
    12-28-2006 07:29 AM in reply to: apojoe69
    teiarch said;
    I say to teiarch, try out your suggestions B4 you suggest them. Yours don't work.
    OK joe, to eliminate the "hook", you also have to eliminate the mtext, so just check the none box under Leader Line & Arrow, then add your own text.
    I tested mine first teiarch, and.... it works!!! :-)
    Re: dimension hook
    12-28-2006 02:35 PM in reply to: apojoe69
    Hey, madcadd: How's it going? Like I care.....
    Re: dimension hook
    12-29-2006 06:50 AM in reply to: apojoe69
    I know...and now, I don't either, why? Because I only have one day left 'til retirement. Yes sir, Tues. Jan 2, 2007.
    When you are occupying that chair they have reserved for you at the Track, have me paged sometime...I may be there.
    Michael Davidson, or just Mike. It's a long shot that we'd be there at the same time, but life is full of coincidences. I'll be the good looking 60 yr old that looks 50....52.....55 tops!
    Have a great 2007!
