• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    Active Contributor
    dataextraction
    513 Views, 8 Replies
    12-09-2009 11:51 AM
    I am extracting data with dataextraction. I can get the information from the drawing and I can see it in the preview. When I click finish and open the Excel file nothing is there. Anyone else have this problem?
    Please use plain text.
    *Dean Saadallah
    Re: dataextraction
    12-09-2009 12:27 PM in reply to: maryannet
    Did you specify a location and file name? File format?
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Active Contributor
    Re: dataextraction
    12-09-2009 01:18 PM in reply to: maryannet
    Yes, I did and the Excel sheet was created but all it said was "Delete Me". I finally saved it as a *.csv file and it worked.
    *Dean Saadallah
    Re: dataextraction
    12-09-2009 02:27 PM in reply to: maryannet
    delete me?
    Dean Saadallah
    Active Contributor
    Re: dataextraction
    12-09-2009 02:37 PM in reply to: maryannet
    Yes, that was in cell A1. Just "Delete Me". The remainder of the sheet was blank. I am wondering if data extraction in AutoCAD 2010 does not work with Excel 2003 for some reason. I have never had this problem before.
    Distinguished Contributor
    Re: dataextraction
    01-08-2010 08:44 AM in reply to: maryannet
    i'm having this exact same problem.
    did you ever find out what the cause was?
    i did the same type of data extraction the other day, on another project and it worked fine. so i'm guessing there is something wrong with my files...
    i'm using acad '10 and excel '07
    Active Contributor
    Re: dataextraction
    01-11-2010 08:36 AM in reply to: maryannet
    I saved it as a *.csv file instead of *.xls and it worked. Do not know why but it worked and I was able to open it in Excel and save it to *.xls.
    Re: dataextraction
    01-11-2010 08:40 AM in reply to: maryannet
    i'll try that.
    i did get it to work last week directly to an .xls file.
    but i had to use acad 2009 to do it...
    makes it even stranger.
    Light_Guy
    Re: dataextraction
    12-19-2011 07:06 AM in reply to: dxarhoulakos
    I am having this same issue using ACAD 2011. Works fine using 2010 and I have tried it on other machines that have acad 2011 and it works but for some reason, on my machine, all I get is the 'DeleteMe in cell A1 of the output file. I have tried it using drawings from my local drive and the network and still the same results. HELP!
    Paul Hamor
    "Always good ships!"
